Activity › Forums › Boris FX Particle Illusion › PI 3.0.4.3 Crashing
  • PI 3.0.4.3 Crashing
    Posted by Terry Mitchell on May 10, 2012 at 12:50 am
    After adding more emitters to my libraries today, one of them now causes PI 3.0.4.3 to crash whenever I try to load it. The only thing different about that particular library is that it is over three times the size of any others (it is about 90,800 kb). If an emitter library gets too big, can it cause PI to crash?
    Alan Lorence replied 14 years, 4 months ago 2 Members · 2 Replies
  • Terry Mitchell
    May 10, 2012 at 2:52 am
    Update: I found and even larger emitter library (97,000+ kb) that loads just fine, so library size is not the cause of the crash. Could it be that the problematic library got corrupted somehow?
    Can I use the backup version of that emitter library (with the “.bak” extension) by renaming it to have an “.il3” extension and copy/paste it in the library folder?
  • Alan Lorence
    May 18, 2012 at 2:41 pm
    Yes, you can do this (rename a backup copy).
    Alan.
    Alan Lorence
    Product Manager
    GenArts, Inc.
    http://www.genarts.com
    http://www.wondertouch.com
