Activity Forums Apple Final Cut Pro Legacy “overexposed frame with misalignment” transition
  • “overexposed frame with misalignment” transition
    Posted by Joel Peregrine on June 15, 2009 at 6:37 pm
    Hi all,
    I’ve been using a manual technique to create “this overexposed frame with misalignment” transition effect but it doesn’t look nearly as convincing as in this example:
    https://www.vimeo.com/4472980
    Is there a transition for sale that exists to simplify the process of getting that effect at a cut? I’ve just spent some time looking and nothing jumps out at me.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Joel Peregrine replied 17 years, 3 months ago 2 Members · 2 Replies
  • Steve Eisen
    June 15, 2009 at 6:51 pm
    Saphire-Genarts, Boris BCC, Noise Industry FX Factory Pro, Industrial Revolution and Adobe After Effects.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Joel Peregrine
    June 15, 2009 at 11:38 pm
    Hi Steve,
    I’ve downloaded all the trials for those and many others but still have seen what I’m hoping is out there. I would have run across it by now I think. The reason that I think its possible to combine effects into a convenient transition is because of plugins like this, which seems to combine so many different attributes into a very easy-to-apply package:
    https://www.digital-heaven.co.uk/dh_retrotv
    Right now I’m combining three different elements to come up with a (not quite yet but close) organically convincing in-camera film cut. I have artbeats film effects as a screen composite above an additive dissolve with keyframed registration adjustments. It works, but its time consuming compared to what I think is possible by someone much smarter than I…
