Activity Forums VEGAS Pro original video much clearer than preview/rendered video
  • Calla Bodnar
    April 23, 2014 at 8:01 pm
    It is set to blend fields, so I don’t think thats the issue. Might just be an issue with VLC media player.
  • John Rofrano
    April 24, 2014 at 11:30 am
    [Calla Bodnar] “It is set to blend fields, so I don’t think thats the issue. Might just be an issue with VLC media player.”
    Is VLC the only place that you see this? Other media players are fine?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Rida Saleeb
    April 28, 2014 at 1:56 pm
    I’ve noticed, There is a difference between the Preview Full HD and the rendered HD image, which exhibits that extra probable Bit Depth, more comparable to better image viewers.
    independent
  • John Rofrano
    April 28, 2014 at 6:23 pm
    [Rida Saleeb] “I’ve noticed, There is a difference between the Preview Full HD and the rendered HD image, which exhibits that extra probable Bit Depth, more comparable to better image viewers.”
    Preview Full i still “preview” quality. The rendered HD will use Good Full by default so it should look better. If you want to see what the render will look like you should use Good Full as well in your preview window.
    ~jr
Page 2 of 2
