Activity › Forums › Adobe After Effects › objects orbit but maintain vertical orientation
  • objects orbit but maintain vertical orientation
    Posted by Paul Dougherty on March 8, 2013 at 3:19 pm
    I used to know how to do this but have forgotten. I want to orbit objects in 2D space (imagine them glued to the hands of a clock) at the center is some stationary object. Like the cars on a frees wheel I want them to maintain their vertical (north-south) orientation as they go round,.How do I do this?
    I remember this from animating text around a vector circle, but can’t remember what I’d do with layers. Thanks in advance.
    Paul
    Dustin Parsons replied 9 years, 4 months ago 3 Members · 9 Replies
  • 9 Replies
  • John Cuevas
    March 8, 2013 at 3:53 pm
    You would parent them to a null at the center of your comp and rotate the null. Then on the objects you would alt-click on rotation, pick whip to the null and add minus sign to counter the nulls rotation.
    -thisComp.layer("Null 1").transform.rotation
    Here’s a sample project if I wasn’t clear: 5612_rotation.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Paul Dougherty
    March 8, 2013 at 3:58 pm
    Wow thanks, I wish I could access that project but I’m only in AE 10.5
  • John Cuevas
    March 8, 2013 at 4:04 pm
    Here you go: 5613_rotationcs5.5.aep.zip
    Hope this helps you out.
    Thinkck.com
  • Paul Dougherty
    March 8, 2013 at 4:18 pm
    This example is AE generated text, I trust this will work with image layers as well?
    Thanks so much
    Paul
  • John Cuevas
    March 8, 2013 at 4:21 pm
    Easier to upload if I don’t use images, but it will work with images too. Glad I could help out.
    Thinkck.com
  • Paul Dougherty
    March 8, 2013 at 4:23 pm
    By Jove I think I’ve got it!!!
  • Paul Dougherty
    March 8, 2013 at 5:39 pm
    a pal suggested animating along a path – which is probably what I used to do
  • John Cuevas
    March 13, 2013 at 10:27 pm
    Glad you got it worked out.
    Thinkck.com
  • Dustin Parsons
    May 11, 2017 at 11:13 pm
    Thanks! Still works 😉
