Activity › Forums › Adobe Premiere Pro › NVIDIA Card with Yosemite and Premiere causing major graphics failure
John Vargo replied 8 years, 10 months ago 60 Members · 268 Replies
Brian Cooney
August 7, 2015 at 11:30 amSince I back installed Mavericks two months ago, I haven’t had any issues and still getting the processing speed of CUDA running CC2015.
Telly Award Winning Editor and Motion Gfx Artist with MotionFoundry, Inc., Nashville, TN. Former Head of Post Production, Coca-Cola Studios Atlanta, GA.
David Roth weiss
August 7, 2015 at 3:32 pm[Thomas Engelaer] “If you go to system preferences and then Nvidia driver manager then under graphics drivers you can select OSX
default driver. Up until now its working for me so its good to try.”The default driver works Thomas, but you’re not getting any GPU hardware acceleration.
David Roth Weiss
Director/Editor/Colorist
David Weiss ProductionsDavid is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Houston Bass
August 11, 2015 at 2:44 amJust installed driver 7.061 that released today.
Hoping for a fix by now. I’ll update if I have any significant findings.
Fred Connors jr.
August 12, 2015 at 12:07 amI thought that Yosemite was required for CC2015.
Did you reinstall Maverick while keeping CC2015 installed.?
THanks
The Troupe – Modern Media Design & Production
Brian Cooney
August 12, 2015 at 4:22 amI did a clean install. of Mavericks and CC2015 works with CUDA and things are much better. Been running on Mavericks for a few months now.
Brian Cooney
August 12, 2015 at 4:23 amto clarify.. I whipped the machine installed mavericks then software and plugins.
Niels Gramsen
August 16, 2015 at 8:43 pmGuys I’m not on a NVIDIA graphic card but on an Intel HD 3000 and AMD Radeon HD 6750M and I’m suffering from the exact same issues as everybody has here. OSX is on Yosemite 10.10.4 , Macbook Pro is a 15 inch from late 2011. Going to try to update OSX to 10.10.5 , going down from PPro CC to CS6 and check if I can update drivers. No idea if this is gonna do any good but I’ll give it a shot.
Brian Cooney
August 16, 2015 at 10:21 pmMay I ask why you wouldn’t consider running on Mavericks? It fixes the glitch issue to the best of my knowledge. Worked for me and others. And you can still run CUDA if your’e on NVIDIA and also CC2015 runs pretty much flawlessly..
Andrew Kimery
August 16, 2015 at 11:31 pm[Niels Gramsen] “Guys I’m not on a NVIDIA graphic card but on an Intel HD 3000 and AMD Radeon HD 6750M and I’m suffering from the exact same issues as everybody has here. OSX is on Yosemite 10.10.4 , Macbook Pro is a 15 inch from late 2011. Going to try to update OSX to 10.10.5 , going down from PPro CC to CS6 and check if I can update drivers. No idea if this is gonna do any good but I’ll give it a shot.
“I’ve the same laptop and running CC2014 in OS 10.8.5 w/o any problems. Out of curiosity have you had your motherboard replaced by Apple? There is a known flaw w/the GPU that eventually leads to the computer locking up and refusing to boot. On my MBP I first notice the problem when the GPU became taxed so the problems you are seeing might be related to the hardware defect, not to the drivers/OS X.
Thomas A. johnson
August 31, 2015 at 4:32 amI have been dealing with this problem, like the rest of you. The whole 9 yards of multiple rounds of Apple support, replaced logic boards, and general finger pointing regarding whose fault this issue was. After today’s Premiere update,I just pulled three CUDA renders without glitches occurring. I’m hoping this is a good sign.
-TAJ
