Activity Forums Apple Final Cut Pro Legacy NTSC or PAL mini DV camcorder confusion
  • NTSC or PAL mini DV camcorder confusion
    Posted by Harry Powell on September 30, 2007 at 7:17 am
    Hi
    Hope it’s ok to post this here as I will be using the camcorder in question with FCP (couldn’t find answer in archives and relevant helplines are closed today)
    I’m in the UK and I’ve ordered a Sony HC38 camcorder from UK site ebuyer.com. But I’ve since noticed that in the small-print that it’s NTSC and not PAL!
    Isn’t this going to cause me problems as over 99% of the work I do will be in PAL (mainly budget DVD authoring/editing showreels).
    Or perhaps there are advantages to the NTSC model? i.e. isn’t there an issue with european DV camera’s being disabled for ‘DV-input’, and wouldn’t this disable monitoring FCP edits via the camcorder onto a TV?
    I’ve discovered what looks like the PAL equivalent of the HC38 i.e. the HC37, so I could cancel and order that insead from elsewhere.. if I’m quick!
    DH
    p.s. if anyone can recommend a better camcorder for the same budget (around
    Rafael Amador replied 18 years, 11 months ago 4 Members · 6 Replies
  • Paul Dickin
    September 30, 2007 at 7:53 am
    Hi
    An NTSC camcorder in the UK is not a good choice unless your edited products will all have to be viewed in the USA.
    Standards converting its video to PAL format to work properly with UK televisions gives a quality loss.
    As you say a very low price PAL camcorder bought in the UK/EU may have its DV-in facility removed, which can mean those models are unsuitable for your needs.
  • Rafael Amador
    September 30, 2007 at 8:32 am
    [DarkHorse] “i.e. isn’t there an issue with european DV camera’s being disabled for ‘DV-input’, and wouldn’t this disable monitoring FCP edits via the camcorder onto a TV?”
    That was years ago. now all the cancorders with DV-Out have DV-In.
    Don’t waist your money in a NTSC camcorder if you work in PAL -and.
    Rafael
  • Paul Dickin
    September 30, 2007 at 10:57 am
    Hi
    Not true in the EU and UK, where input-enabled video recorders have been classed differently from players, for duty purposes.
    No current UK-model Sony DV cameras seem to have iLink and Mic inputs except the VX2100E.
    Quote:
    DCR-HC37E
    Jacks
    Audio Input NO
    Audio Output YES
    Video Input NO
    Video Output YES
    S-Video Input NO
    S-Video Output YES
    i.LINK (DV) Input NO
    i.LINK (DV) Output YES
    USB Terminal NO
    External Microphone Input NO
    Headphone Jack NO
    https://www.sony.co.uk/view/ShowProduct.action?product=DCR-HC37E&site=odw_en_GB&pageType=TechnicalSpecs&imageType=Main&category=SDH+MiniDV#tab
  • Walter Biscardi
    September 30, 2007 at 11:18 am
    [DarkHorse] “Isn’t this going to cause me problems as over 99% of the work I do will be in PAL (mainly budget DVD authoring/editing showreels).”
    Yes. You’ve ordered the wrong camera. You need a PAL camera or one that can shoot both PAL and NTSC for that 1% of work that will be NTSC.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Harry Powell
    September 30, 2007 at 7:07 pm
    Thanks for your responses. I’ve cancelled the order.
    Looking back I’m not surprised that I missed the fact that the HC38 was NTSC, considering it was from a UK site selling (virtually) all PAL equipment. Hopefully you can see what I mean: http://www.ebuyer.com/UK/product/127420
    And if indeed the (PAL) HC37 firewire input is disabled, is there not a way of ‘abling’ it? (i.e. a bit like region restricted DVD players can often be easily made multiregional). And is this just a Sony ‘quirk’?
    I suppose an analogue video input is completely asking too much LOL. Am I mistaken in recalling from years ago that this was a common feature of Sony camcorders so that you could convert your old vhs tapes to DV?
    It’s all a bit frustrating, but might still go for the Sony HC37 unless anyone has any alternative suggestions for the budget (i.e. in order of importance: ext mic input, FW in, analogue video in..)
    DH
  • Rafael Amador
    October 1, 2007 at 2:54 am
    I made a Google search about the HC37, and it seems that is a model that only has been sold in the UK.
    I remember that until the year 2000 (more or less) the MiniDV cameras they were selling in the continet they had no DV-IN no analoge video in, because they had to pay some royalties or so. But I remember that when I bough mu SONY DCR PC-120, (in 2001) all the camcorders they were selling (at least in Spain) they had DV-IN-OUT and Video-IN-OUT.
    Now it seems that the most of HD and DVD camcorders have not DV-Video IN.
    You should have a look because they are very similar models, some with only DV-Video out, some with IN-OUT. I found the DCR-HC 40 and DCR-HC 96, that are basically the same than the DCR-HC 37, but those have DV and analoge Video in.
    Cheers,
    rafael
