Activity › Forums › DaVinci Resolve › Normally scaled but not on Render
  • Normally scaled but not on Render
    Posted by Robbie Carman on June 8, 2011 at 10:15 pm
    Hi guys
    I’m having an issue that I’m trying to get my mind around. 99% of my work is back to SR through a legalizer but increasingly we’re being asked for file based delivery and deliver FCP projects with graded sequences in them for clients to do laybacks later on.
    In Resolve I’m working with the Normally Scaled Legal Video option on. On my Ultrascopes I correctly see overshoots and undershoots being clipped as they should. However after rendering I get the session back to FCP I see the overshoots/undershoots. Which leads me to believe that the Normally Scaled Legal Video option is working for monitoring only and not on render.
    So my questions has anyone else had this issue (btw going back to Prores HQ)? Something I’m missing while rendering?
    Is a LUT the only way to go here?
    Robbie Carman
    Colorist and Author
    Check out my new Books:
    Video Made on a Mac
    Apple Pro Training Series DVDSP
    From Still To Motion
    Twitter
    Blog
    Michael Stirling replied 15 years, 3 months ago 8 Members · 22 Replies
  • 22 Replies
  • Robbie Carman
    June 8, 2011 at 11:03 pm
    never mind – user error been that kind of day 🙂 All is working as it should
    Robbie Carman
    Colorist and Author
    Video Made on a Mac
    Twitter
    Blog
  • Christopher Tay
    June 9, 2011 at 1:37 am
    Hey Robbie..how did you fix the problem ?
    -chrispy
  • Robbie Carman
    June 9, 2011 at 1:43 am
    I some how prior to rendering switched my config to one that was full range. Not sure how I did that but as I said it has been that kind of day. Switched back to normally scaled, re-rendered and all was right with the world.
    Robbie Carman
    Colorist and Author
    Video Made on a Mac
    Twitter
    Blog
  • Ola Haldor voll
    June 9, 2011 at 10:01 am
    Good! Phew.. Got a little nervous there for my own sake.
  • Christopher Adams
    June 9, 2011 at 12:27 pm
    How are you normally set up? Do you have it set to full non scaled for display then set it to scale on render?
    CJ
  • Ola Haldor voll
    June 9, 2011 at 12:50 pm
    I always have it set on scaled.
  • Christopher Adams
    June 9, 2011 at 1:09 pm
    Is that for both values?
  • Gabriele Turchi
    June 9, 2011 at 1:16 pm
    Being set to scaled , it does just scale on the preview ,
    when you render , it does render at full ,
    But the following app that will receive the footage will apply “the scale” again , and here depends on the app and the codec …
    QT if is YUV will apply the scale
    QT if RGB will it display as full
    FCP apply the scale on SDI (and on the viewer if is YUV)
    Flame/Smoke apply scale on SDI
    etc…
  • Christopher Adams
    June 9, 2011 at 1:26 pm
    So what you are saying is that it always renders out at full scaling. Once the editor gets it back they may want to add a legalizing filter to catch anything we missed? Obviously we grade and use our scopes then do soft clipping when needed. But is that the workflow you guys tend to use? Let the editor if he is finishing run a filter as the final catch all?
    CJ
  • Gabriele Turchi
    June 9, 2011 at 1:35 pm
    i actually did not said that at all.
    i said that FCP (over the SDI) and QT (for YUV codec) and FLame (on SDI) does it automatically without set anything or apply a legalizer …
Page 1 of 3
