Activity › Forums › DaVinci Resolve › No Reel No – How to reconnect
Posted by Frederic Lumiere on January 7, 2012 at 9:13 pmHaving the hardest time going from AVID with DNxHD to Reslove. Clips have no reel No and are offline.
How to reconnect the clips in Resolve?
All the clips show fine in the default. I used AAF.
David Steiner replied 14 years, 8 months ago 8 Members · 18 Replies -
Joseph Owens
January 7, 2012 at 10:00 pm[Frederic Lumiere] “All the clips show fine in the default.”
I don’t really understand this statement.
However, are your DNxHD clips Quicktime.mov or in MXF wrapper? QT DNxHD is not a Resolve-supported codec.
jPo
You mean “Old Ben”? Ben Kenobi?
Frederic Lumiere
January 7, 2012 at 10:17 pmWell the issue is that when importing an AAF in Resolve the clips are offline. I assumed it was because of lack of reel numbers but after unchecking ‘Assist using reel numbers from the:’ many clips now connect fine.
Just have a few stragglers with the error “can’t be linked because the timecode extents doesn’t match”
Any idea why that would be?
Also, is there a way to reconnect the few offline clips manually?
Yes, they are MXF DnxHD.
Thanks for your help!
Frederic Lumiere
January 7, 2012 at 10:20 pmAhhh – also i’m discovering that some clips aren’t showing the correct edit – way off…
Frederic Lumiere
Producer
Lumiere Media -
Frederic Lumiere
January 7, 2012 at 10:35 pmCould this be an issue with 24p vs. 23.98?
Resolve doesn’t offer 23.98 timebase does it?
Frederic Lumiere
January 7, 2012 at 10:38 pmI chose to consolidate the clips during the AAF creation process (it’s a short 2 min trailer) and all the clips in the media pool look perfect but they aren’t connected to the imported timeline with a couple exceptions.
Vladimir Kucherov
January 8, 2012 at 5:19 amhttps://forums.creativecow.net/thread/277/11879
Is this the issue you’re running into?
I unfortunately don’t know of a solution to that myself.
Frederic Lumiere
January 8, 2012 at 5:26 amThat’s exactly it. The majority of my clips don’t even connect but the time codes are wrong.
Frederic Lumiere
Producer
Lumiere Media -
Jonathan Tremblay
January 8, 2012 at 6:11 amYou could try to add a reel number inside avid by right clicling and use modify. I got thaf kind of problem when i have a motion effects in my timeline with keyframes on it. Kill it if you have.
After the modify you could create new master clips and mxf to send to resolve using the aaf export option…
Have you tried a edl?
Sorry if i sound robotic, im writting on a phone.
David Steiner
January 9, 2012 at 5:42 am[Jonathan Tremblay] “You could try to add a reel number inside avid by right clicling and use modify.
“the “modify” can only set a source tape
how can one add reel names to clips in avid?
the main problem is that with a lot of tapeless workflows (5D/7D, AVCHD), there is no reel name and TC starts at 1:00:00:00 for EACH file.
it could work is reel name was file name. but copying the “clip name” column into the “reel #” fails, avid says “column is not modifiable”.
anybody has a solution?
thanks
Jonathan Tremblay
January 9, 2012 at 7:28 pmOh sorry! I read your post too fast…
You could try to export an ALE and modify the column by hand…?
