Activity › Forums › DaVinci Resolve › No Reel No – How to reconnect
Roman Hankewycz
January 10, 2012 at 12:37 amAre the clips you’re having trouble with multicam clips by any chance?
roman hankewycz
harbor film company // colorist -
David Steiner
January 10, 2012 at 12:46 amnope, they’re not multicam clips…
and I couldn’t even say I have “trouble” with them, it’s worse: since 5D/AVCHD-originated files have no “reel number” per se associated with them when they’re imported into Avid and have TC always starting at 1:00:00:00
so in my understanding there isn’t any reel name for Resolve to find the images (and TC isn’t enough since they all start at 1:00:00:00)… so the roundtrip back to Avid doesn’t work (Avid -> Resolve works since AAF directly references the path to the files)
David
Charlie Edison
January 10, 2012 at 8:14 amtry exporting with consolidate media option, add handles if you wish and choose the highest DNx transcode setting….
take all that across to resolve and try again..
might help ?
Roman Hankewycz
January 10, 2012 at 2:57 pmDavid,
I’m testing the 5D to AVID to Resolve workflow myself and have the same problems. Will let you know if I come up with something.roman hankewycz
Roman Hankewycz
January 10, 2012 at 7:13 pmDavid,
I successfully tried out 2 workflows outlined by Blase Theodore in a post of mine: https://forums.creativecow.net/readpost/277/13198
I’m curious to hear if it works for you. They require some manual labor but sending to Resolve via EDL and AAF worked.roman hankewycz
Prathvish Hegde
January 11, 2012 at 11:30 amif you are able to import all clips into resolve using an aaf and every thing is fine the when you are roundtriping once you render the shots also export a edl or xml from resolve and it should work
prathvish hegde
colorist -
Prathvish Hegde
January 11, 2012 at 11:32 ami am not sure if there is a export aaf option in the conform page…..will get back
prathvish hegde
colorist -
David Steiner
January 11, 2012 at 7:16 pmin the Conform tab one can export in AAF. so after the render, the AAF does work and I can import into Avid.
the only thing is the AAF only “hard links” to the resolve-rendered files, so I can’t “relink my original sequence” to the graded images, I can only “import the AAF into a new sequence”
so going back to Avid does work, but with a “AAF-crunched” sequence, which might or might not work with effects.
basically, I figured it might be better to simply export the final render from Resolve directly
I explained my simple workflow on another thread: https://forums.creativecow.net/readpost/277/13374
Cheers
David
