Activity Forums Apple Final Cut Pro Legacy NEX-FS100 footage and Final Cut — Is there a way?
  • NEX-FS100 footage and Final Cut — Is there a way?
    Posted by Brian Pitt on April 10, 2012 at 5:21 pm
    We recently purchased a Sony NEX-FS100. Great camera…
    I’ve spent the past few hours trying to find the best workflow to get the footage into Final Cut. The bad news is that I haven’t found much. Should I just jump ship and migrate to Premiere Pro now, or is there a good way to transcode this footage to a format that Final Cut will work with? I tried mpeg stream clip, but it doesn’t seem to recognize the source footage. I also tried Final Cut’s log and transfer, but couldn’t get that to work either.
    Does anyone have any advice for me?
    Brian
    Brian Pitt replied 14 years, 5 months ago 2 Members · 6 Replies
  • Shane Ross
    April 10, 2012 at 5:26 pm
    Yes…Log and Transfer. Here’s the workflow:
    https://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
    Shane
    Little Frog Post
  • Brian Pitt
    April 10, 2012 at 5:30 pm
    Thanks ,Shane.
    I’ll try doing that after watching the video. I didn’t have luck doing so the first time, but I might have been doing something wrong. I appreciate your response.
    Brian
  • Shane Ross
    April 10, 2012 at 5:31 pm
    Make sure you are running 7.0.3. If it still doesn’t work, use ClipWrap2 to convert the footage to ProRes.
    Shane
    Little Frog Post
  • Brian Pitt
    April 10, 2012 at 5:33 pm
    I’m running 6.0.6 🙁
    Brian
  • Shane Ross
    April 10, 2012 at 5:35 pm
    Then you need to use ClipWrap. That camera came out many years AFTER FCP 6…so it doesn’t see the format of AVCHD it records.
    Shane
    Little Frog Post
  • Brian Pitt
    Thank you for your help. It is much appreciated.
    Brian
