Activity Forums Adobe Premiere Pro Newbie Question: Easier way to add an effect to multiple clips?
  • Newbie Question: Easier way to add an effect to multiple clips?
    Posted by Tim Bob on June 15, 2006 at 10:58 pm
    Is there a way in PP to add an effect to multiple clips at the same time? It gets annoying when I have to add something to tons of clips in the timeline one by one. Any easy way around this? I’m new. Thanks
    Tim Kurkoski replied 20 years, 2 months ago 2 Members · 1 Reply
  • Tim Kurkoski
    June 16, 2006 at 12:32 am
    You can’t drag an effect onto multiple clips at once, but you can apply the effect to one clip, copy the effect from the Effect Controls window, and then select all the other clips and choose Paste.
    You could also put all your clips into a nested sequence and apply the effect to the sequence, if you want to use the same effect settings on all of them.
