Activity Forums VEGAS Pro New update for Pro 11
  • New update for Pro 11
    Posted by Mike Kujbida on December 16, 2011 at 8:42 pm
    Merry Christmas from Sony 🙂
    https://www.sonycreativesoftware.com/download/updates/vegaspro
    Notable fixes/changes in version 11.0 (Build 510/511)
    Updated Sony AVC format render template customization to support AVCHD 2.0.
    Added StreamChase® feature for editing media while it is being ingested by an XDCAM® Professional Media Station.
    Added Sony Tablet presets to Sony AVC format.
    Improved performance for MVC reading.
    Added support for 24p MVC as well as support for additional 3D cameras (such as the Panasonic Z10000).
    Re-enabled support for “Mono (multiple)” templates for AIFF and Wave formats.
    Add the ability to create folders in Compositors window.
    Added Titles & Text Scroll Left preset for creating text crawls.
    Extended Titles & Text animation from first line to all lines for built-in presets.
    Added GPU acceleration for Pan/Crop rotation as well as Track Motion rotation, shadow, and glow.
    Added GPU acceleration for all track compositing modes.
    Added GPU acceleration to the Swap, Push, Slide, Squeeze, Spiral, Zoom, Barn Door, and Split transitions.
    Added GPU acceleration to the Invert effect.
    Added GPU acceleration to the Checkerboard generator.
    Improved GPU-accelerated image quality for downscaled images.
    Implemented some performance improvements in ProType Titler and Titles & Text generators.
    The cursor now stops at the exact end of a recorded event when recording is paused (for example, when using the Enter key).
    Upload to YouTube has been updated according to the YouTube specification: commas (not spaces) are used to delimit tags, and single-character tags are not allowed.
    Projects burned to Blu-ray Disc from the timelines now show elapsed time on hardware players.
    Fixed a crash that could occur when creating transitions using NumPad * or -.
    Fixed a crash that could occur when using audio plug-ins protected with PACE iLok system.
    Fixed a crash that could occur when rendering to ATRAC Advanced Lossless format.
    Fixed a crash that could occur when exiting the application after playing back time stretching on audio events.
    Fixed a crash that could occur when opening certain unsupported MXF files.
    Fixed an issue with Burn Timeline to Blu-ray Disc that caused an invalid Blu-ray image to be created when using the MainConcept MPEG-2 video format.
    Fixed an image glitch that could occur with GPU-accelerated MainConcept AVC rendering.
    Fixed an issue with GPU accelerated Sony AVC rendering using AMD Catalyst 11.10 or 11.11.
    Fixed an issue reading MPEG-2 files with non-Latin characters in the file name or path.
    Fixed an issue displaying certain non-Latin characters in ProType Titler and Titles & Text.
    Fixed issues when using nonsquare pixel aspect projects with some video plug-ins.
    Fixed an that prevented double-clicking an OFX pop-up fader from setting the correct default value.
    Fixed an issue where transitions would not appear on the Transition shortcut menu.
    Fixed an issue with Chroma Keyer changing colors when used in 32-bit floating point mode without GPU acceleration.
    Fixed an issue with Pixelate producing incorrect output when used without GPU acceleration.
    Fixed issues with Color Curves and Levels when used with images containing transparent alpha channels.
    NVIDIA drivers prior to R270 are not allowed for GPU-accelerated video processing as they can cause crashes.
    Fixed Paste Event Attributes to also paste OFX keyframes.
    Fixed an issue that could cause events to use the wrong media in certain circumstances (seen when project is later loaded).
    Fixed scroll wheel support for devices with high-resolution scroll wheels.
    Fixed an issue that prevented mouse clicks from selecting the active multicamera take when external monitor full-screen view was enabled.
    Fixed duplicate devices that could be displayed in Device Explorer.
    Fixed issues with External Controls not being detected when added and MIDI learning in Control Configure not working.
    Fixed an issue with closing audio ports when Close audio and MIDI ports when not the active application was enabled in Preferences > General.
    Geoff Candy replied 14 years, 7 months ago 18 Members · 24 Replies
  • 24 Replies
  • Julie Conroy
    December 16, 2011 at 10:36 pm
    when I tried to update it erased the version of 11 I have and said there was an error of some sort and 11 is gone. System restore brought it back but am now afraid to update.
  • Mark Krueger
    December 17, 2011 at 12:06 am
    HALLELUJAH!!!!
  • Bill Church
    December 17, 2011 at 1:37 am
    Julie, the same thing happened to me when I tried to update, after Vegas had alerted me to the new build. Rather than use the restore function to get it (the original installation) back, I opted to go back to the Sony downloads page and download the update again. This time, it sailed through the installation and I was where I needed to be, in build 511, including Titler Pro and my other third-party plug-ins. It didn’t even ask for the serial number. Try it again and you should be good to go.
    Bill Church
    Briarwood Productions LLC
  • Angelo Mike
    December 17, 2011 at 2:06 am
    It’s about time. I’ll have time to try it next week.
    http://www.scenethroughglass.com
  • Darren Hugh
    December 17, 2011 at 2:34 am
    YES!!! That was one of the best christmas presents I got this year! Solved my problem from earlier with the image glitches instantly!
    Thank you Sony!
  • Steve Rhoden
    December 17, 2011 at 9:37 am
    Hope most issues are sorted out!
    Steve Rhoden
    (Cow Leader)
    Film Maker
    Filmex Creative Media.
    1-876-832-4956
    https://filmex-creative-media.blogspot.com/
  • Jim Greene
    December 17, 2011 at 2:35 pm
    Wow. Not sure I’m ready to switchover yet, since I still have 1 PC running V10 on WinXP, but the render performance is amazing with the GPU acceleration. The same 2:34 project, with about 35 h.264 .mov events (Canon 5D) takes 3:26 to render in V10, vs. 1:40 to render in V11. Twice as fast! (Contrast that with over 5 minutes on WinXP quad-core with SVP10). All clips with color correction, some with secondary CC, all cropped to 2.35:1 frame. One event is reversed, which comparatively takes a lot of time to render. Output is Sony AVC 1280×540 24p 6Mbps. Preview seems just slightly better in V11, but I think my CPU is the workhorse there instead of the GPU. Computer specs: Win7 Pro, NVIDIA GTX570, Intel i7-3930K, 16GB RAM.
    -Jim.
  • Geoff Candy
    December 17, 2011 at 10:55 pm
    Still won’t ‘Print to HDV tape’
    VP11 Capture HDV from tape, add files to matched timeline and Print to HDV to tape. Timeline renders out but does not print to tape.
    VP10: Add captured clips from above and Print HDV to tape.
    Works every time.
    Now reopen VP11 and print the file rendered out in VP10. Again works every time.
    However; VP10 cannot print the rendered m2t file prepared in VP11 back to tape.
    2 updates and a basic feature still not working!!
  • Steve Rhoden
    December 17, 2011 at 11:31 pm
    Geoff, You kidding me !!!
    Steve Rhoden
    (Cow Leader)
    Film Maker
    1-876-832-4956
  • Geoff Candy
    December 17, 2011 at 11:48 pm
    Steve: Wish I was.
    Tests.
    HDV (tape) m2t files captured from the camera and dropped on a matched timeline and selected.
    Tools>Print to HDV tape selected. (delete rendered file unchecked). Timeline renders out, camera swichtes into record mode, tape rolls but viewing screen (on camcorder)remains blue.
    Repeat test using same clips but in VP10. Again clips render out but this time the file is correctley written to tape.
    Whilst still in VP10 try printing the file prepared by VP11 in first test.
    The message The file type is unknown: C:\******\’Print 11 to tape.m2t’ is displayed
    Back to VP11 try printing back the file rendered out by VP10.
    This prints to tape correctly.
    Strange thing is that I can put the file rendered in VP11 onto a timeline in VP10 and render out from here. No recompression reqired is displayed and file prints down to HDV tape
    There appears to be something wrong with the file prepared for tape in VP11. Repeatable on 2 pc’s using same HDR-HC3 camcorder.
    This has been reported to SCS
    If you can suggest any other tests I’d be delighted to get this solved.
Page 1 of 3
