Activity › Forums › Apple Final Cut Pro Legacy › New to HD in FCP
New to HD in FCP
Posted by Angela Zumbrum on May 6, 2011 at 3:10 pmI am editing with FCP version 6.0.6. We recently switched our cameras to Panasonic AG-HMC40 AVCCAM HD Camcorder. I am importing the footage into FCP. FCP is dragging and very slow. I need guidance on what I need to change all of my FCP setting to. I am new to the HD world. Any help would be much appreciated. Thank you!!!
Angela Zumbrum replied 15 years, 3 months ago 6 Members · 23 Replies -
Chris Tompkins
May 6, 2011 at 3:30 pmView the “Tapeless WorkFlow” tutorial by Shane Ross here on the cow.
Chris Tompkins
Video Atlanta LLC -
Rafael Amador
May 6, 2011 at 3:31 pmHi Angela,
HD requires more processing power than SD.
Are you using L&T?
This is a great introduction for your workflow:
ttp://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
Once your stuff is Prores, you edit as usual.
Rafael -
Shane Ross
May 6, 2011 at 4:57 pmTapeless Workflow for FCP 7 Tutorial
Just fixing the link Raf…you forgot the “h” in http..
Shane
Read my blog, Little Frog in High Def -
Rafael Amador
May 6, 2011 at 6:50 pmSorry about (where are my glasses?).
BTW, you have any idea of how may clicks have the tutorial?
I’m sure must be one of the video related docs more trafficked in the last few months in Internet.
Raf -
Angela Zumbrum
May 6, 2011 at 7:07 pmHI thank you for your help. Actually, the footage has already been transfered from the camera’s card onto an external hardrive. The cameras are being used, so the people that I work with never actually give me the card.
I copied the footage from the hard drive to my computer and brought it into FCP that way. All of the clips are .mov files. Is this really bad? The footage looks great, but is very slow. There is no way I can edit this way. Should I change the sequence settings and FCP preferences?
Rafael Amador
May 6, 2011 at 7:24 pmYour media must be now Prores.
I don’t know about your system and what are you trying to do, so I can’t know if your slow performance is normal or not.
Try to easy he RT setting (Unlimited RT).
rafael -
Angela Zumbrum
May 6, 2011 at 7:35 pmChanged to Unlimited RT and is still dragging. I am using
Mac OSX 10.5.8
Processor: 2×2.8 GHz Quad Core Intel Xeon
Memory 2GB 800Mhz DDR2 FB-DIMM
I watched the tutorial that you recommended, and tried to log the footage. However, FCP will not open these clips, saying that file format is not supported. How would I change these .mov clips to prores?
Thank you for replying so quickly.
Chris Tompkins
May 6, 2011 at 8:45 pmDid you try Importing the files? Not L&T?
If FCP won’t open the files then you need new files.Chris Tompkins
Video Atlanta LLC -
Rafael Amador
May 6, 2011 at 9:03 pm[Angela Zumbrum] “Changed to Unlimited RT and is still dragging. I am using
Mac OSX 10.5.8
Memory 2GB 800Mhz DDR2 FB-DIMM”
Where are you storing the media?
rafael -
Angela Zumbrum
May 6, 2011 at 9:11 pmHere is my path thus far:
Dragged the files from external drive to my internal hard drive.
Next, “Imported” the files into FCP.
I can open the files after import….but when I try to view them..they drag and FCP almost shuts down.
When I tried to L&T it would not allow me to. So importing was my only option.
