Activity › Forums › Apple Final Cut Pro Legacy › New to HD in FCP
  • Angela Zumbrum
    May 30, 2011 at 1:33 pm
    Hi Guys!
    Finally got all of the .MTS file transferred to ProRes. Footage is in FCP and now everything seems to be working fine. However, I am uncertain about my sequence settings. What should I have all of my sequence settings at? I tried searching this topic, before asking, but can’t seems to find a complete break down. Thank you for your help!
  • Chris Tompkins
    May 30, 2011 at 2:25 pm
    Your sequence should match your clips.
    You shot 1920X1080.
    Do you convert to Prores 1080?
    Are you @ 60i or 30p or 24p?
    Look @ your clips in the browser.
    Drop a clip into a new sequence and let FCP change sequence settings to match.
    Chris Tompkins
    Video Atlanta LLC
  • Angela Zumbrum
    June 9, 2011 at 11:43 am
    It’s me again! I am finally done with this HD edit, and exporting. I have been reading other posts and this is what I have tried so far:
    Export quicktime – current settings
    Export quicktime – apple ProRes22
    and I have now used compressor using DVD BEst 150 min. leaving me with m2v and ac3 files.
    Here is my problem: The video is dragging after dvd burn, and even worse, it’s a tiny box in the middle of the screen??? It doesn’t fill the screen? Is this something that I have done wrong in FCP? or during my exporting?
    Thank you for your help.
    Also, will idvd support HD?
Page 3 of 3
