Activity › Forums › Adobe After Effects › New mouse… Can’t zoom in, only out!
Posted by Christian Wheel on February 15, 2010 at 6:29 pmHello,
My MS Intellimouse (which I LOVED by the way), finally died. I replaced it with a Microsoft Explorer Mouse. Not a bad mouse, still getting used to it.
Problem is, the mousewheel no longer zooms in for AE. When I scroll the mousewheel, regardless of the direction, it zooms out. Zoom IS, however, working properly in every other program I use it to zoom with (Paint Shop Pro, various 3rd party programs, even in the Zaxwerks plugins)… Just not AE.
Anyone experience this before and/or know a fix?
—– Christian Wheel —–
Radio Host, 104.3 MyFM, Los Angeles
Audio Production & Imaging
MS Visual Studio Developer
After Effects EnthusiastJeff Giles replied 12 years, 3 months ago 8 Members · 12 Replies -
Todd Kopriva
February 15, 2010 at 9:22 pmWhat operating system? What version of After Effects (including updates)?
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment. -
Christian Wheel
February 15, 2010 at 10:25 pmVista x64, AE CS4 9.0.2.42.
After Effects Enthusiast -
Todd Kopriva
February 15, 2010 at 10:35 pmHmmmm… I just tried the same setup (same OS, After Effects version, and an Explorer 4.0 mouse), and I’m not seeing the same behavior. Rolling the wheel forward and backward with the pointer over the Composition panel zooms in and out as it should.
Please file a bug. Here’s a link to the feature-request/bug-report form.
Also, check to see if there are updates for the mouse driver. And it wouldn’t hurt to try some different settings for scroll wheel speed and sensitivity in the Windows Control Panel.
Sorry I don’t have a ready answer.
Joseph W. bourke
February 15, 2010 at 11:34 pmHi –
I’m experiencing exactly the same problem with a MS Wireless Laser Mouse 5000 and AE CS4 with the latest updates, running on Vista 64 bit. I can zoom out (waaaaay out), but the zoom in with the mouse wheel does not work at all, nor does scrolling the thumb with the mouse wheel when I’m in the timeline or project view. These features work with the same AE CS4 version running on Windows XP Pro 32 bit (but a different mouse – MS Optical Mouse 3000). I’ve tried changing the sensitity settings, and a number of settings, with no solution. It’s very frustrating, because this was a feature I used all the time. Thanks.
Joe Bourke
Creative Director / Multimedia Specialist
B&S Exhibits and Multimedia
bs-exhibits.com -
Christian Wheel
February 15, 2010 at 11:50 pmGlad to know I’m not alone.
If I plug in a wired mouse, the zoom works as expected. I also seem to be having zoom issues with this mouse in Picasa. This leads me to believe it’s a problem between the Microsoft Mouse driver and some Windows API call that AE and Picasa are both using.
I just tried submitting a support ticket to M$, but their ticket system is down and they “apologize for the inconvenience.” Ugh.
Christian Wheel
February 15, 2010 at 11:57 pmOOOH!!!! FIXED THE PROBLEM!! By going to a different mouse driver!
How to solve, in 10 easy steps:
1) Go to control panel… Device Manager.
2) Locate your mouse in the device list.
3) Right click it, and go to “Update Driver.”
4) Select “Browse my computer for driver software.”
5) Choose the “Let me pick from a list of device drivers on my computer” option.
6) Uncheck the “Show compatible hardware” checkbox.
7) Under “Manufacturer,” choose Microsoft.
8) Change the model to “Microsoft USB IntelliMouse.”
9) Ignore any warnings that come up about it possibly being incompatible.
10) Your mouse will freeze for a moment, and then come back, with FULL ZOOMING ACTION in After Effects.
Hope this helps!
Scott Morrison
February 16, 2010 at 2:32 amI was SOOO excited to try this after being frustrated as all heck with my Wireless Mouse 5000. I followed your instructions (albeit with the changes necessary because I am running Windows 7).
No good. Same problem.
I went to Microsoft and updated the drivers for the mouse…still no good. I even tried every possible driver I could think of..
nada.
But thank you for the tip. I’ll keep fussing with it.
Christian Wheel
February 16, 2010 at 7:12 pmIt could be the Wireless Mouse 5000 simply won’t take another mouse’s driver. 🙁
And in some of my tests to find a mouse that worked, the mouse stopped working altogether, forcing me to resort to keyboard shortcuts to continue.
The only problem with this solution on my end so far is that the scroll wheel acceleration is way too high, and changing it in settings has no effect.
Sorry it didn’t work for you – You may just have to bite the bullet and get a different mouse. Sucks.
Ben Römer
April 7, 2010 at 11:18 amI had the same problem but found a solution!
Hope this works for you guys as well.Here you can get the X-Mouse Driver: https://www.highrez.co.uk/downloads/XMouseButtonControl.htm
In the preferences you don’t have to change much, just set “Wheel Up”
to “Mouse Wheel Sroll Up”.That should do it. Of course, the driver needs to be running all the time.
But hey, you can ZOOM in AE! Isn’t that incredible? 😉 -
Nathan Marcus
December 11, 2010 at 10:04 pmHi,
I had the same problem, my new Microsoft mouse wouldn’t zoom in or out in After Effects, although it would in Google Chrome and other programs, so I tried your steps.
And when I came to step 10, my mouse froze like said, and then my PC showed the Blue Screen of Death, rebooted, got another BOD, rebooted again and started System Recovery, I tried that but afterwards it failed and rebooted, I tried System Recovery 3 times, and only then it worked, but I’m glad my PC is working now.
I think it my mouse which probably isn’t equal to yours (Wireless Mobile Mouse its called)I just wanted to say this for people who will also try it.
Greetings,
Nathan
