Activity › Forums › Apple Final Cut Pro Legacy › new apple codec
new apple codec
Posted by Delano Bryant on August 20, 2007 at 4:19 pmrs422, are you setting it up with 1080i/60. Can you use this codec and capture through firewire from an XL H1? I have a blackmagic decklink hd extreme on order. suggestions?
Chris Borjis replied 18 years, 8 months ago 9 Members · 40 Replies -
Shane Ross
August 20, 2007 at 4:30 pmNot via firewire. You can only capture as ProRes 422 (RS-422 is deck control) if you have FCP 6 and a capture card…OH, and an intel mac. The only capture card that has a hardware ProRes encoder is the AJA I/O HD.
Shane
Littlefrog Post
http://www.lfhd.net -
Uli Plank
August 20, 2007 at 4:46 pmAFAIK the Canon H1 has an SDI output. With that one you can capture via the Blackmagic card directly to ProRes 422 on an Intel Mac.
Regards,
Uli
Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
Delano Bryant
August 20, 2007 at 5:04 pmThere is a way to capture via sdi and firewire at the same time? how do you keep audio and video sync?
Shane Ross
August 20, 2007 at 5:14 pm[hdfilmmaker] “There is a way to capture via sdi and firewire at the same time?”
No…one or the other. Not both.
[hdfilmmaker] “how do you keep audio and video sync?”
If you capture via firewire, audio is there and in sync. If you capture via HD SDI, then you need to connect the AUDIO OUTS of the camera (XLR) to the audio INS on the capture card…basic connections.
Shane
Littlefrog Post
Walter Biscardi
August 20, 2007 at 5:18 pm[hdfilmmaker] “Can you use this codec and capture through firewire from an XL H1?”
No.
[hdfilmmaker] “have a blackmagic decklink hd extreme on order. suggestions?”
If that card can convert to ProRes on the fly and you have either a G5 Quad or a Mac Pro Intel machine, then yes, you can convert the signal to ProRes.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Mark Maness
August 20, 2007 at 5:56 pmReally?
The only reason I say that is…. I have a couple of Sony M10U decks and we captured thru the AJA box that converted component video to HD-SDI (no audio), and then the audio was captured thru the firewire along with machine control. I never had a sync issue.
Maybe the Canon camera ca do this… Maybe its a Sony thing only… Give a shot and see what happens.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
https://blogs.creativecow.net/waynecarey -
Shane Ross
August 20, 2007 at 6:01 pm[Wayne Carey] “I have a couple of Sony M10U decks and we captured thru the AJA box that converted component video to HD-SDI (no audio), and then the audio was captured thru the firewire along with machine control. I never had a sync issue.”
REALLY? Well blow me down. I had no idea. I have always only seen in the setups ONE OPTION for capturing…either Firewire or capture card.
Learn something new…
Shane
Littlefrog Post
Delano Bryant
August 20, 2007 at 6:02 pmI know that we’ve captured JVC footage with our blackmagic hd extr. and we’ve captured over 50 hrs and no sync issues.
Delano Bryant
