Activity Forums Apple Final Cut Pro Legacy new apple codec
  • Jerry Hofmann
    August 20, 2007 at 7:04 pm
    The Decklink product will probably down convert on the fly so you could do things that way.
    I’d buy as much machine as you can afford. There’s not many of them anywho….
    I’ve only used their top of the line machine, and it seemed OK, but I’ve never used it but one time.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Mark Maness
    August 20, 2007 at 7:05 pm
    [Shane Ross] “So I captured with my Kona LH as DVCPRO HD.”
    This is the best overall workflow when HDV. This is my personal experience.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
  • Mark Maness
    August 20, 2007 at 7:07 pm
    [walter biscardi] “Too much conversion. You’re going to take HDV, convert it to ProRes to edit, convert it back to HDV when it’s output to the Sony MU15 and then convert it again to beta.”
    Oh my… I agree. Let your capture card do the conversion for you, if needed. Then make an HDV copy ONLY as a backup, if you need.
    Wayne Carey
    Schazam Productions
  • Delano Bryant
    August 20, 2007 at 7:08 pm
    Jerry how are the classes going up there in Denver? Don’t you teach up there? Anyway, I’m reading some RSS on the net about the JVC and some people are saying they WON’T play canon tapes. BTW, we also have a huge library shot on the XL2 that I need to be able to capture back without having to use the cameras. Which deck works?
    Is that the color red you want to use?
  • Mark Maness
    August 20, 2007 at 7:11 pm
    THAT’S IT!
    Jerry has got it!
    Exactly on all points. This has been my only issue with ProRes. AJA saw this issue and solved it for us from the start. No one else has even considered to tackle ProRes. Thanks, AJA!
    Jerry took the time between edits fro fill in the gaps!
    Wayne Carey
    Schazam Productions
  • Delano Bryant
    August 20, 2007 at 7:43 pm
    Will the Sony mu15 deck play canon tapes? I’ve searched all over between the JVC and the sony. I need a deck that will play the 1080i canons as well as some tapes shot on XL2.
  • Steve Boultbee
    August 20, 2007 at 8:15 pm
    [Jerry Hofmann] “2. You can’t capture to prores unless you have an intel mac… Apple suggests a quad in fact. Power PC machines aren’t up to the task.”
    According to Apple’s Final Cut Studio System Requirements, “Capturing HD resolution video using the ProRes 422 format requires a Mac Pro with an Intel Xeon processor or a G5 Quad computer and a qualified third-party capture card.”
    The ability for the G5 Quad to capture ProRes was added in the 6.0.1 update, I believe.
  • Delano Bryant
    August 20, 2007 at 8:18 pm
    Ive got the new update. I do not have the new black magic card. I will get that this thursday.
    Which tape deck should I use to play back Canon tapes?
  • Walter Biscardi
    August 20, 2007 at 11:52 pm
    [hdfilmmaker] “and prores is 1440×1080 right?”
    ProRes is full raster 1920×1080
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Chris Borjis
    August 25, 2007 at 11:03 pm
    Use any sony HDV deck to playback the canon HDV tapes.
    It will work on everything EXCEPT 24f canon mode.
    The JVC WILL NOT (I own one) playback any HDV except
    JVC’s HDV.
    And for the record my G5 Quad with a multibridge extreme will still not capture HD prores without dropping frames with the 6.01 update.
Page 4 of 4
