Activity › Forums › Apple Final Cut Pro Legacy › networking G5’s?
networking G5’s?
Posted by Chris Baldwin on November 22, 2006 at 6:15 amIs it possible to network 2 G5 Dual Cores so that they share processor and ram rather than just hard drives?
Chris
Chris Baldwin replied 19 years, 10 months ago 4 Members · 4 Replies -
13
November 22, 2006 at 6:32 amyes but i believe it is cald a cluster not a network
I believe that you use Apple Qadministrator to do it, I cant realy say how because I have never done it.
Arnie Schlissel
November 22, 2006 at 4:26 pmThis is what the University of Virginia did a couple of years ago when the first G5s came out. They hooked up maybe 1,000 of them into a single cluster & created a supercomputer. If you search on Google, or Wikipedia, or even the UV website, you could probably find more info.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Kevin Monahan
November 22, 2006 at 7:00 pmChris,
You can not chain G5s together to share rendering duties if that’s what you were thinking. Only for Shake and Compressor duties.Kevin Monahan
Take My FCP Master’s Workshop!
fcpworld.com
Pres. SF Cutters -
Chris Baldwin
November 27, 2006 at 12:31 amI’d love to be able to boost my encoding performance of Compressor. So creating a cluster will do this? I wonder to what effect?
Its gonna cost between $7000 to $10000 to get a new quad core with 4gigs of ram and some other hardware I’d like to upgrade to.
Buying a used Dual Core PowerPC G5 and clustering it with my current G5 is gonna cost me about $2500.
Is there any way to determine what type of perfomance boost I can expect from encoding duties? If its minimal maybe its just not worth it, but if I can cut 6hour exports in half or so that’d be GREAT!
Do you think I’m chasing my tail or is clustering G5’s a valid value solution?
I wonder if there are any links that describe setting up this cluster?
Chris
