Activity Forums Apple Final Cut Pro Legacy Need help with video capture keyboard shortcuts
  • Need help with video capture keyboard shortcuts
    Posted by Mediacentral on August 19, 2005 at 2:28 pm
    I apologize if this has been asked and answered a hundred times before but I have just switched from Media100i to FCP5 and am still on the learning curve.
    Is there a keyboard shortcut to start capturing a clip? I know the space bar plays and pauses, j,k and l for forward and reverse and escape stops capture. My problem is that I am starting a project which will have a couple hundred cover shots, all between 5 and 10 seconds long and the idea of using the mouse to hit capture all of those times is frustrating.
    Media100 has all of the machine control on the number pad, which makes the process on FCP seem that much more daunting.
    Any help is greatly appreciated. Thanks in advance.
    Rick Sebeck replied 21 years, 1 month ago 2 Members · 3 Replies
  • Rick Sebeck
    August 19, 2005 at 4:52 pm
    You could remap your keyboard to the media 100 style. And as far as capturing shortcuts… F2 “logs clip” then you can do a batch capture. I didn’t fully appreciate the Log and Capture window, until the first time I had to log a feature film. Believe it or not, it is AWESOME. Mark in, Mark out, name roll, name scene, name take.. press F2. It then sets the outpoint to the next inpoint, and sequences the take number.
    I’ll admit it can be clumsy if your not logging in the traditional film setting.
  • Mediacentral
    August 19, 2005 at 6:55 pm
    Thanks for responding, Rick. Unfortunately,the clips I need to capture are all cover/b-roll stuff which will have multiple takes of pushes/pulls/pans/tilts on different subjects, which means I will have to pretty much go through each tape in real time to pick the best ones. Logging them all like that (hundreds of clips) and then going back to batch capture would likely take twice as long as just suffering through the mouse clicking. I just find it strange that they have a keystroke for everything except capture.
  • Rick Sebeck
    August 22, 2005 at 6:17 pm
    You could always do the “capture first, log later” approach. If you have the drive space, capture the entire clip, then open the clip in the viewer and add markers at each take. Then, from the browser select the markers and drag them into a new bin. FCP will turn them into sub clips. Rename them how you’d like, and your good to go.
