Activity › Forums › Apple Final Cut Pro Legacy › Need advice with Time Remapping –
  • Need advice with Time Remapping –
    Posted by Bryan Fowler on November 13, 2008 at 12:41 am
    I’ve always had problems with time remapping in final cut pro.
    It seems that it’s very hard to be precise.
    I want to be able to go to a point in a clip, scrub, roll, slip or whatever, until it’s at the frame I want, then say “stay!” Then run back or forward a few frames and do the same. Or ramp from slow up to normal speed…
    It seems whenever I turn on time remapping, it adjusts the whole clip, and whatever changes I try to make, are affected by any other changes I make.
    I freely admit to missing things often. I’m hoping someone can point me in the right direction to what I may have missed.
    Another thing… the motion tab seems very hard to get useable feedback with time remapping… I open the motion tab, but things are not easy to see there. Almost like I need to zoom way in on the clip, but the motion tab won’t let me.
    help my ignorance out guys. (i’ve seen a few tutorials, and they are nice, but still seem to miss something for me)
    Bryan
    Lars Fuchs replied 17 years, 10 months ago 3 Members · 3 Replies
  • Lars Fuchs
    November 13, 2008 at 1:42 am
    One thing I almost always do is make a subclip of the footage I want to manipulate with time-remapping. The time-remap graph scales to the size of the ENTIRE source clip (including the handles) so if you’re using clip that several minutes long or longer the graph covers just too much material to be precise. Its easiest if you subclip only the frames you want, but then you lose handles. (The difference between avid and fcp subclipping will have to be the subject of another thread.)
    Another thing you can do is enlarge the viewer window to as big as you can make it on your monitor. Then enlarge the time-remap portion of the motion tab by pulling down on the baseline so that the time-remap is as big as possible. that will give you more room to work. If you find yourself doing this a lot, set up a window layout that way, and one for your normal workflow. If you name the layouts so that they’re alphabetically the first two of all your layouts, you can use the keyboard shortcuts to switch back and forth between them.
    You can also use the time remap tools (hit ‘S’ three times) in the timeline to adjust the timing of the clip, but I haven’t been able to get my head round them. The time remapping is counter-intuitive for an ex-Avid head like myself, so I generally don’t use them. But the manual makes them sound really cool. The can be used to do exactly what you describe: pin a particular frame in a clip to a particular time in the sequence.
    Good luck!
  • Tom Wolsky
    November 13, 2008 at 1:51 am
    Subclipping an FCP clip will not have any effect on time remapping. It still accesses the whole media file. You have to export the portion you want to time remap and then reimport the file.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Lars Fuchs
    November 13, 2008 at 2:46 am
    [Tom Wolsky] “Subclipping an FCP clip will not have any effect on time remapping. It still accesses the whole media file. You have to export the portion you want to time remap and then reimport the file.”
    Actually, I just checked this. In FCP 6.0.3, using NTSC DV footage, I created a 3:28 subclip from a master clip 8:13:21 in length. I edited the subclip into the sequence; then I cut the same media into the sequence from the original master clip with the same mark-in and out that I used to create the subclip. I opened each in turn in the viewer by double-clicking.
    The subclip behaved as I expected – the start of the ramp was frame 0 (the first frame of the sub) and the top of the ramp was frame 118 (3:28). When I opened the master clip the start of the ramp was frame 7166, and the last 7284, or 118 frames, out of a scale that went from 0 to 14795. Visually they were quite different: the subclip displayed a nice nearly 45 degree ramp, while the master clip was basically a horizontal line.
    So indeed, you will get more precision if you subclip your footage before time-remapping it, at least if the source clip is considerably longer relative to the clip length in the timeline.
    Here are some screen grabs:
    Subclip:
    Picture 1
    Master Clip:
    Picture 2
