Activity Forums DSLR Video ND Filter Step up rings!
  • ND Filter Step up rings!
    Posted by Justin L. on September 15, 2011 at 10:51 pm
    Alrighty. I’m planning to buy this ND filter (recommended by CheesyCam) https://www.ebay.com/itm/58mm-Fader-ND-F … 3cb0ce57be .
    But this size is only for the kit lens. And I’m actually planning on buying the nifty fifty Canon 50mm 1.8 soon. What step up rings would you guys recommend? And what size nd filter should I buy (largest?)? So this way, I think I can save more money so that i don’t have to buy filters for all my lenses!
    Rob Macmullan replied 14 years, 9 months ago 3 Members · 2 Replies
  • Rob Manning
    September 17, 2011 at 12:24 am
    Hello Justin,
    Step rings can cost around $30 or more, or, less than $10 at places like Samy’s Camera on the West Coast for generic versions.
    The link you show, is DOA.
    The ND Fader is what you want to add to the gear correct? These are not the same as the ND Filter (AKA Grad) which have a horizon line across the filter used to try and separate bright sky, or sea, salt flats etc. from the rest of a composition.
    The ND Fader, is two filters, one which rotates (Polarizer) allowing for a 4 to 8 stop adjustment in collected light and are a must for field or studio capture in HDslr video.
    Prices spread across a range and (I’m not certain) but they vary based upon glass/plastic optics and brand.
    I bought the largest one to fit my 70-200 and 24-70 which thread at 77mm, but instead of buying the same brand (Genus) filter adapter rings, I bought generics for the other threaded lenses, 52, 58, 62, and 67 which cover our lens locker generally.
    The Genus company are fine folks, but on a budget I purchased Kenco adapters all five for about the price of a single Genus.
    Not sure what those differences are, perhaps aircraft grade aluminum or something like that.
    Also, if you buy in a store, be sure to make the selection for step up or step down, as there are both and not all sales folks know which is which.
    If I’ve stated the obvious on the subject, it’s because the link would not fly, hence the explanations. Besides, I was chasing around another forum using the incorrect nomenclature and just wanted to be sure you meant ND Fader.
    HTH’s,
    Rob
  • Rob Macmullan
    December 22, 2011 at 11:40 pm
    Ever use an ND fader with multiple step-up rings? I’m thinking of following your suggestion and buying an 82mm ND fader with step-up rings for all of my lenses: 52mm, 67mm, and 77mm. However, I can’t find a 52-82mm step-up ring and I’m wondering if I can use a 52-67mm AND 67-82mm for the 82mm ND.
    Canon XHA1, T2i, Apple iMac 27″, FCP, CS4
    http://www.CreativIntent.com
