Activity Forums Apple Final Cut Pro Legacy Multiple dialog windows cause FCP to hang
  • Multiple dialog windows cause FCP to hang
    Posted by Drew Lahat on August 8, 2012 at 9:12 pm
    This has happened to our editor twice this month (FCP 7.0.3):
    We dragged a file into the browser, and got an error. That’s fine, usually you’d hit OK or Cancel, but “Preparing Video for Display” showed up – and then you’re toast. The error window buttons are nonresponsive and “Preparing Video” is stuck, so you have to Force Quit.
    I think the first instance of the problem was with an autosave notice during a File Open dialog.
    This seems like nothing with bad prefs, but coding oversight. I know FCP7 is EOL, just wanted to see if anyone else has experienced this issue.
    Drew Lahat replied 13 years, 11 months ago 2 Members · 2 Replies
  • Shane Ross
    August 9, 2012 at 12:21 am
    What file are you dragging into the browser?
    Shane
    Little Frog Post
  • Drew Lahat
    September 20, 2012 at 1:59 am
    Hi Shane,
    Haven’t seen a pattern with the file type. Last time it was ProRes Quicktime. Today it happened again – twice. I was importing an XML and the “Preparing video for display” opened and hanged on top of the XML import dialog.
