Activity Forums Avid Media Composer Multi Camera Edit in Composer 11
  • Multi Camera Edit in Composer 11
    Posted by Brian Mills on April 26, 2006 at 2:42 pm
    Im trying to edit a 2 camera video and im havng a problem with the multicamera edit tool. When i go to watch the 2 cameras in the quad mode Im nto able to see both cameras just 1. Should I be able to see both cams at once playing…because im not….when i stop the seq from playing then i can see them…
    Thanks for any info
    Brian
    Brian Mills replied 20 years, 3 months ago 1 Member · 2 Replies
  • Brian Mills
    April 26, 2006 at 2:54 pm
    Heres the actual problem Im having…my group clip is not playing in the source window when i play the sequence in multicamera mode…could this be a graphics card problem?
  • Brian Mills
    April 26, 2006 at 5:45 pm
    didnt digitize my footage at M setting…oops.
