Activity › Forums › Apple Final Cut Pro Legacy › Mpeg2 Muxed
Mpeg2 Muxed
Posted by Steve Denn on December 20, 2008 at 4:01 pmHello
Doesn’t FCS come with mpeg2? I have a mpeg2 muxed file I can’t open via QuickTime 7.5.5. but I can view it using VLC. I have downloaded this :30 commercial to be air.
The site states I need mpeg2 to open this file, which I thought I had.Any help on this one.
Thanks.
G5 DUAL 2 IBM Chip Set – 4gigs of Ram
Leopard 10.5.5
FCS 6.0.5Kim Trampus replied 17 years, 4 months ago 7 Members · 16 Replies -
Tom Wolsky
December 20, 2008 at 5:11 pmThe MPEG-2 playback component is part of the FCS install, but the format is not directly supported within Final Cut.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Rafael Amador
December 20, 2008 at 5:18 pmDownload MPGStreamclip.
You will be able to play the file or convert it to a QT movie.
Rafael -
Steve Denn
December 20, 2008 at 6:46 pmI just tried MPEG Streamclip. Nothing happened, I dragged the file into it’s window & it was blank, but it acted as if there was video there. I then hit the play button, & it moved the positioning bar but the screen was blank. If it helps anyone I can upload a small portion of the clip.
I’m puzzled why a free download suck as VLC plays it back, but QuickTime on my desktop will not play it. It’s just a white screen. Which tells me I’m missing a CODEC.
Thanks again.
G5 DUAL 2 IBM Chip Set – 4gigs of Ram-
Leopard 10.5.5-
FCS 6.0.5 -
Tom Wolsky
December 20, 2008 at 6:51 pmYou’re going to need to find out a lot more about this file. It’s not a standard MPEG-2 file. Where’d you get it from? How did it get into your computer?
All the best,
Tom
Steve Denn
December 20, 2008 at 7:06 pmTom
Format of this file says it’s a 3GPP2
The spot came from here
https://adcouncil.theadspot.tv/
& was downloaded to my desktop.
Leopard 10.5.5-
FCS 6.0.5 -
Tom Wolsky
December 20, 2008 at 7:14 pmThat’s a phone format.
The web site is protected. If they want you to use this material it should be delivered in a different format.
All the best,
Tom
Steve Denn
December 20, 2008 at 7:24 pmTom
That’s what comes up when I try to export it from QT.
When I open it via command J within QT it says it’s a MPEG2 MuxedThanks
Leopard 10.5.5-
FCS 6.0.5 -
Tom Wolsky
December 20, 2008 at 7:28 pmWhat does movie info say? Not properties.
All the best,
Tom
Steve Denn
December 20, 2008 at 7:39 pmKind: MPEG Movie
Codes: MPEG2 Muxed
Do you mind if I send you the file direct? it’s 77megs
Thanks Again
Leopard 10.5.5-
FCS 6.0.5 -
Tom Wolsky
December 20, 2008 at 8:25 pmHow are you going to send it to me? You can’t email it. I’ll download it from somewhere if you like.
All the best,
Tom
