Activity Forums VEGAS Pro .mp4 Files Imported to Sony Vegas Only Show Audio
  • .mp4 Files Imported to Sony Vegas Only Show Audio
    Posted by Eloise Thibault on July 15, 2010 at 6:48 pm
    I have a lot of .mp4 files that I need to import into Sony Vegas Pro 8.0, but when I try, only the audio appears. I just need the video for what I’m making, so if anyone could help me find a way to get both or just the video, that would be fantastic. I’ve tried converting some of the videos to .avi, but they get pixelated at times. I tested them in Windows Media Player and Windows Movie Maker, and they don’t appear like that on there, so I don’t know what the problem is. If you can’t help with the .mp4 problem and know how to fix the problem with my converted videos, that would be helpful, too. Thanks in advance.
    Rob Burkhardt replied 16 years, 1 month ago 5 Members · 14 Replies
  • 14 Replies
  • Mike Kujbida
    July 15, 2010 at 6:59 pm
    The most likely problem is that you updated QuickTime on your computer, either automatically or through iTunes.
    You need to uninstall the current version and install 7.6.4 which is available on the Avid site.
    It still works with the latest version of iTunes but will not work with video from the new iPhones.
  • Eloise Thibault
    July 15, 2010 at 7:10 pm
    Well, I tried that now and now it doesn’t show either the video or audio. I’ll keep trying other things, but if you or anyone else has any other suggestions, I’m willing to test them.
  • Mike Kujbida
    July 15, 2010 at 7:24 pm
    Did you re-boot your computer after the uninstall – reinstall?
  • Eloise Thibault
    July 15, 2010 at 7:40 pm
    Yeah, it still doesn’t work when I do that.
  • Mike Kujbida
    July 15, 2010 at 9:49 pm
    This is very strange as my suggestion usually works.
    Where did the files originally come from?
  • Eloise Thibault
    July 15, 2010 at 10:13 pm
    I downloaded the videos from Megaupload. I think I came up with an alternative way of doing this, though. I’m converting the files to a different kind of .avi than I did before (called “MS Compatible AVI on the WinFF converter I’m using) and they seem to be working well on Vegas. It will take me forever to convert all of them, but oh well.
  • John Rofrano
    July 16, 2010 at 2:38 am
    I don’t believe Vegas uses Quicktime for MP4 files (just MOV). Try installing the x264vfw codec and see if that helps.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Rob Burkhardt
    July 25, 2010 at 11:56 pm
    Where do I get the x264vfw codec?
    Rob The Video Guy
  • John Rofrano
    July 26, 2010 at 12:16 am
    It’s an open source project at sourceforge.net. Just download the latest build.
    ~jr
  • Rob Burkhardt
    July 27, 2010 at 7:42 pm
    OK I down loaded the latest build but I still can’t get the video to play back.
