Activity Forums VEGAS Pro Moving audio event limits back into alignment with video
  • Moving audio event limits back into alignment with video
    Posted by Anthony Atkielski on July 12, 2012 at 1:10 pm
    I have been using ‘/’ to insert crossfades of audio across simple cuts in video, and it works great. But sometimes I want to move events around, and it would be really convenient if there were a keyboard shortcut that would take the edge of the audio for an event and snap it back into alignment with the edge of the video. Is there such a shortcut? I can’t find one in the online help, but I’m not sure what to look for.
    Right now, I just put the cursor on the edge of the video event, then slide the audio back into alignment, but if there’s a way to do this with one key, that’d be great. I know about Ctrl-/ to change an audio crossfade back to a cut, but it only works when two events are butted together, not after you slide them apart.
    Anthony Atkielski replied 14 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
