.mov file import… audio but no video!
Posted by Gilles Gagnon on April 4, 2011 at 7:24 pmI’ve captured some footage off a Sony cam. Client used FCP to create .mov files from the footage and provided these.
When I import them in Vegas Pro 9, I get audio only. No video track is imported.
I can view the video and audio if I open the .mov file in VLC player.
what gives?
Thanks for any leads,
Gilles
Gilles
Gilles Gagnon replied 15 years, 5 months ago 5 Members · 13 Replies -
John Rofrano
April 4, 2011 at 8:07 pmWhat version of QuickTime 7 do you have and what version of Vegas Pro 9? You’ll need at least Vegas Pro 9.0d to use a QuickTime version greater than 7.6.2.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Gilles Gagnon
April 4, 2011 at 9:35 pmHI John,
I’m using Vegas Pro 9.0e and Quick time 7.6.6.
Gilles
Gilles
Mike Kujbida
April 4, 2011 at 10:28 pmThat version of QT should be able to play the files.
What kind of Sony camera did the footage come from?
What does QuickTime player say about the video (Window – Show Movie Inspector)? -
Douglas Spotted eagle
April 4, 2011 at 11:20 pmThird party codecs unchecked in Prefs?
Douglas Spotted Eagle
VASSTCertified Sony Vegas Trainer
Aerial Camera/Instructor -
Gilles Gagnon
April 5, 2011 at 12:01 am -
Mike Kujbida
April 5, 2011 at 12:12 amGilles, is there any chance of getting the original source footage?
It’s HDV which Vegas will load and edit very easily instead of having to jump through hoops like you are right now. -
Rob Franks
April 5, 2011 at 12:16 amSomething odd with that. HDV is normally 1440×1080. The duration is pretty short as well… is that 1.27 seconds correct?
I notice the clip’s title states 24fps yet the specs indicate 29.97. Is this 24p in a 60i wrapper (24p with pull down)?
Gilles Gagnon
April 5, 2011 at 12:16 amYes, Mike, I can get the original footage but it will delay the project.
It seems silly that I have a .mov file which will play with VLC player but will not import video in Vegas.
getting the original footage is my last resort. Am I at the last resort??? 🙂
Gilles
Gilles
Gilles Gagnon
April 5, 2011 at 12:19 amyes, for this test clip 1.x seconds is correct. all my other footage is longer… and behaves in the same manner.
not sure about the settings reported. I didn’t do the FCP capture. The cam was set 30fps as far as I know.
G
Gilles
April 5, 2011 at 2:50 amyou wanna FTP me a short clip?
