Activity › Forums › Adobe After Effects Expressions › Motion Math with AE7
Posted by Sascha1979 on July 7, 2006 at 12:48 pmHi.
I can’t find the keyframe assistant as the case may be the option motion math in after effects 7.
Wanted to you the gravity preset like i used before in AE 5.5.thx 4 help
Mike Clasby replied 20 years, 2 months ago 3 Members · 3 Replies -
Mylenium
July 7, 2006 at 2:19 pmMotion Math is dead ever since v6. You have to think of other ways.
Mylenium
[Pour Myl
Mike Clasby
July 7, 2006 at 3:27 pmScripts or expressions, both come with squish and squash.
There is a script call Gravity.jsx
Select the layer you want to apply gravity to,
File > Run Script > Choose File > and you should open up to the folder (demos)
Note: (demos) is a folder nested here (on a PC): C drive > Program Files > Adobe > After Effects 6.5 > Support Files > Scripts > Demos
there should be a file there named “Gravity.jsx”
select it.
Now when you click the “Run Simulation” in the Gravity script palette you’ll get keyframes of the chosen gravity attributes (chosen in the palette). Also a cool plus, if you keyframe position as in moving the ball (or whatever layer is selected when you open the script) you’ll get a nice moving ball bouncing, note two that the layer bounce around a box created in the palette, just click he “?” for details>And this for Gravity Expression from earlier posts:
Date: Mar 22, 2006 at 1:53:30 am
Subject: Re: GravityHere a set of expressions,very nice with squish a squash as the ball bounces, not as hairy as it looks if you can copy/paste expressions (Alt + Click the Stopwatch for the property you want to apply the expression to, then paste)
I just remembered Dan had a nice bouncing animation expression from this post:
Date: Sep 14, 2004 at 11:40:45 am
Subject: Re: bouncing animationHere are a couple of bounce simulation expressions. The first one is for position and the second is for scale. With the parameters set the way they are, your object will drop until it reaches y = 400 (“floor”) and then bounce. You can control everything with the parameters (even better- assign them to sliders). You can use Vx0 and Vy0 to give your object an initial velocity – turning it into a projectile. For best results, move the anchor point of your object to the bottom. Here’s the expression for poisition:
Vy0 = 500; //initial y velocity (pixels/second)
Vx0 = 100; // initial x velocity (pixels/second)
g = 2500; // gravity (pixels/second/second)
floor = 400;
e = .85; //elasticityd = .03; //squash factor
spd= 10; //speed of squash oscillation
decay= 10.0; //how fast squash slows downb = floor – position.valueAtTime(0)[1];
h = b + Vy0*Vy0/(2*g);
T = Vy0/g + Math.sqrt(2*h/g);if (time < T){ x = scale[0]; y = scale[1]; }else{ Vy = -(Vy0 - g*T); while (true){ max_dev = e*Vy*d; Vy *= e; t = T; T += 2*Vy/g; if (time < T){ t = time - t; x=scale[0]+max_dev*Math.cos(spd*(t))/Math.exp(decay*t); y=scale[0]*scale[1]/x; break; }else if (T - t < thisComp.frameDuration){ x = scale[0]; y = scale[1]; break; } } } [x,y] And for scale: Vy0 = 0; //initial y velocity (pixels/second) Vx0 = 0; // initial x velocity (pixels/second) g = 2500; // gravity (pixels/second/second) floor = 400; e = .85; //elasticity d = .02; //squash factor spd= 10; //speed of squash oscillation decay= 10.0; //how fast squash slows down b = floor - position.valueAtTime(0)[1]; h = b + Vy0*Vy0/(2*g); T = Vy0/g + Math.sqrt(2*h/g); if (time < T){ x = scale[0]; y = scale[1]; }else{ Vy = -(Vy0 - g*T); while (true){ max_dev = e*Vy*d; Vy *= e; t = T; T += 2*Vy/g; if (time < T){ t = time - t; x=scale[0]+max_dev*Math.cos(spd*(t))/Math.exp(decay*t); y=scale[0]*scale[1]/x; break; }else if (T - t < thisComp.frameDuration){ x = scale[0]; y = scale[1]; break; } } } [x,y] Dan
