Activity Forums Apple Motion Motion 5 fullscreen problem
  • Motion 5 fullscreen problem
    Posted by Jonathan Geange on September 7, 2011 at 5:43 am
    Can anyone tell me how to get Motion 5 to go fullscreen using the F8 key?
    It says in the settings that F8 is assigned to fullscreen but when I press it does nothing and makes that sound where you’ve pressed an unassigned key?
    This works fine in Motion 4, is this a fix that needs addressing?
    Jonathan Geange replied 14 years, 4 months ago 4 Members · 15 Replies
  • 15 Replies
  • Mark Spencer
    September 7, 2011 at 1:16 pm
    I assume you are on a laptop, which means you need to hold down the fn key before pressing F8 – unless you go into System Prefs, keyboard, and check the “Use F1, F2, etc…” checkbox
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Jonathan Geange
    September 7, 2011 at 10:27 pm
    Thanks for your effort Mark, unfortunately I have tried your suggestions and I still don’t know why this is not working?
    The option is greyed out for some reason, and I only have one project open.
    Not really impressed with Motion 5 so far and it’s looking like I will need to revert back to 4 :/
  • Mark Spencer
    September 7, 2011 at 10:36 pm
    It’s not possible to have more than one project open with Motion 5. Are you sure you are using Motion 5? F8 should say “Player Mode”
    Mark Spencer
  • Jonathan Geange
    September 7, 2011 at 10:54 pm
    Wow that is strange? Yep it sure is Motion 5…this is so bizarre!
    I am running it on a MBP with Lion installed and everything is upnto date.
    Wierd!
  • Mark Spencer
    September 7, 2011 at 11:07 pm
    Ah, you are on Lion – that is the problem.
    Mark Spencer
  • Jonathan Geange
    September 7, 2011 at 11:20 pm
    No way!
    So I can’t get full screen preview with Lion?
  • Mark Spencer
    September 7, 2011 at 11:42 pm
    I believe it’s a bug – we discovered it during our training week before last. Another bug with Lion: in FCPX, if you apply a title, you can’t change its location in the Viewer.
    Mark Spencer
  • Jonathan Geange
    September 7, 2011 at 11:54 pm
    Thanks Mark, I thought I was going crazy!!!
    I really hope they sort that bug out ASAP, I have no choice but to re-install Motion 4 now :/
    Pretty much wasted $50 so far…it’s very slow on my computer compared to M4, mainly due to it being only 16 or 32 bit only.
    Sometimes software updates can be more of a down grade 🙁
  • Mark Spencer
    September 8, 2011 at 12:16 am
    Not being able to do full screen preview is forcing you back to M4?? Why?
    Mark Spencer
  • Jonathan Geange
    September 8, 2011 at 12:29 am
    I’ve devised a system that captures the fullscreen animation using another screen capture program and it is completely ruined if I can’t get the full screen view.
    I will use Motion 5 for other projects.
    Thanks again for your assistance 🙂
