Activity Forums Adobe Premiere Pro More of a Design Question – Dealing with Text and Video
  • More of a Design Question – Dealing with Text and Video
    Posted by Andrew Tucker on September 14, 2018 at 3:12 pm
    Good Morning,
    I work in a corporate environment where I get a lot of colliding feedback from the Up and Ups (we have a shifty approval process). I just introduced them to Screenlight (being new to it myself) and I’m going to have to figure out a way to hammer out a good approval process in.
    One of the most recent situations is one approver likes smaller text and one approver thinks the text needs to be bigger because it is too difficult to read. I can agree on both counts because I enjoy seeing more video but when they want so much text-on-screen it’s hard to figure out a good solution (corporate construction by the way).
    Does anyone have any advice on using a lot of text-on-screen but still making it readable and making the video still viewable. I think my solution is going to come down to having a text slide and then the video to follow for times like this.
    I know it is more of a communication issue but I was checking to see if anyone had advice on having text and video on the same screen?
    Any help is much appreciated, Thanks!
    Andrew Tucker
    Video Specialist
    Reel:
    https://vimeo.com/241594457
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Jon Doughtie replied 7 years, 7 months ago 3 Members · 2 Replies
  • Stephen Smith
    September 14, 2018 at 3:52 pm
    Make sure your client understands that in general people don’t want to read much when they watch a video. A lot of people will stop reading the text if there is too much. If you have a voice in the video then the text is just to reinforce the key points. Without seeing the video or text you want in the video I really can say more than this. Best of luck.
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
  • Jon Doughtie
    September 17, 2018 at 7:30 pm
    You should have them settle it between themselves. Really. Two approvers with rather different points of view? They need to resolve it, and come back to you with a resolution they will both agree on.
    You can’t fix decision-by-committee. Only they can fix that.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
