Activity Forums Maxon Cinema 4D mograph random colouring
  • mograph random colouring
    Posted by Olly Bea on September 16, 2009 at 3:02 pm
    Hey
    I am reasonably new to mograph and I seem to be falling short on the ol’ nogin stuff.
    I have a wall of cylinders (50 x 40) and I want to randomly colour the cylinders with 2 colours of my choice but I can’t seem to fathom out how to do it.
    Any ideas? (Daft question really cos i’m sure you all know how to do it!)
    Cheers
    O
    Chip Webster replied 10 years, 10 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    September 16, 2009 at 4:02 pm
    The easiest way to do it would be:
    1. Select the cloner and then create a random effector (it’s automatically applied to the cloner);
    2. In the effector’s parameters tab, select color mode>on, and check the “use alpha/strength” box;
    3. Create a new material and place the mograph>multi-shader in the color channel;
    4. In the multishader properties, click the arrow to the right of Shader 1 and select the standard color shader from the menu;
    5. Set the color you want in the color shader properties;
    6. Repeat for Shader 2;
    7. Drop the material on your cloner. Use the interactive render region to preview the effect (it won’t display properly in OGL);
    8. Go to the random effector>effector tab and click through the seeds until you get a distribution you like.
  • Olly Bea
    September 16, 2009 at 6:05 pm
    Amazing, you will make my nogin a bigger place! Cheers again!
  • Chip Webster
    October 28, 2015 at 8:17 pm
    To piggy back on this post… Is there a way to only affect some of the clones with the color and not all of the clones. Is there a way to then have the colors randomly undulate or pulse between random clones within the cloner?
