Activity › Forums › Blackmagic Design › MJPEG Codec for HDV
MJPEG Codec for HDV
Posted by Dave Evans on August 11, 2008 at 9:00 pmHi Guys
Any one have experience with Black Magic Intensity as a lower cost option for HD editing in Prem CS3? Need to have reasonably good timeline monitoring out to HDTV display.
I am wondering if there are any merits using the BM MJPEG codec as an intermediary codec instead of editing HDV native. Some captures will be live studio for green screen etc, but most will be from field shot HDV. Can the codec be scaled in Mb/s?
Final destination will be SD DVD for the most part but the occasional output to BD is also on the cards.
Any thoughts advice appreciated.Regards
Dave.
Callum Mclay replied 18 years, 1 month ago 4 Members · 9 Replies -
Margus Voll
August 12, 2008 at 8:26 amHi.
For greenscreen mjpg should be better as i underestand mjpg is 4:2:2 as hdv is only 4:2:0 etc.
Margus
Callum Mclay
August 12, 2008 at 1:28 pmHI Dave
For editing purposes, you should have an easier time editing with the MJPEG codec rather than HDV. The MJPEG codec is intra-frame coded only, whereas HDV is MPEG 2 based, and has temporal redundancy encoding, making it more difficult to edit.
With that said, modern editing machines can handle HDV editing reasonably well, but you will still experience problems for frame accurate cutting, due to the long GOP format of HDV. The MJPEG codec does not have the ability to be scaled, and will stay at the target data rate of around 12 to 15 MB per second.
And as correctly stated above, HDV is still DV encoding, and so has 4:2:0 colour subsampling, whereas MJPEG has 4:2:2, and so you will retain more colour information for your chroma key work.
Callum McLay
Technical Support Consultant
Blackmagic Design EMEA -
Dave Evans
August 12, 2008 at 10:22 pmThanks for taking time to reply Margus & Callum.
May I ask some further questions. How well does the codec play with other applications such as Boris FX, After FX, Procoder 3 for example.
And how well does it scale when downconverting for SD DVD.Thanks for your help, Dave.
Margus Voll
August 13, 2008 at 8:10 amHi again.
4:2:2 scales better as there is more data as you know but generally it is more up to software like in premiere resize might be bad but for instance in combustion resize is class of its own.
So generally it is not so much up in the format specially in downscale.
SO try to test out stuff what you feel works best … as in render time etc. Generally as i see mjpg is like uncompressed with its 422 but it ads a layer of extra work on your machine.
Just test it out make different compression files resize them etc.
Regular R & D to work flow developement.—
Margus
Dave Evans
August 14, 2008 at 5:45 amThanks for the reply Margus.
Just trying to get some info before we decide to take a look at this option.
Are you running CS3 with this card? Is it a stable option?
Regards
Dave.
Martin Vincent
August 15, 2008 at 3:57 pmIts not necessarily extra work, first its not lossless second as its a compressed format it takes a little cpu on the BM card so no problem there, and at last it reduce the bandwidth needed from hard drives a lot so you can capture without a big fat raid 0 or 5 backing up. So its good when you don’t have enough drive space or bandwidth on the drives when using multilayer video in HD 4:2:2 its almost unavoidable.
Dave Evans
August 15, 2008 at 9:31 pmThanks for the comments Martin.
Does this work well for you in CS3 are the any things to look out for.
Regards Dave.
Margus Voll
August 17, 2008 at 5:28 amHi.
In technical point ofcourse it is not lossless but for applications it is something like that compared to hdv and mpg2.
I’d say even digibeta might give you some compression on its 2 to 1 ratio.
Margus
Callum Mclay
August 21, 2008 at 9:55 pmHI Dave
Blackmagic Design currently have full compatibility with Adobe CS3 including Premiere Pro, After Effects and Photoshop.
So you should have a nice stable workflow using Motion JPEG with Premiere CS 3, and the latest Blackmagic Drivers. Please bear in mind that MJPEG as a codec is more CPU intensive than an uncompressed workflow, but much less disk intensive, allowing you to get away with HD Resolution without the need for a hard drive array.
Callum McLay
