Activity Forums Adobe Premiere Pro Missing Master Audio track in sequence and Audio Mixer
  • Missing Master Audio track in sequence and Audio Mixer
    Posted by Jason Hency on March 24, 2017 at 12:59 pm
    Hello,
    I’m trying to pin down why my Master Audio track in any sequence I generate along with in the Audio Mixer is not showing up? I’m using Premiere Pro CC 2017.1 on an iMac running OS X Yosemite, 3.5GHz Core i5, 32GB ram, and an AMD Radeon R9 M295X. I’m hoping this is a simple check this box and voila that i’ve simply been overlooking. Thanks.
    Jason Hency replied 9 years, 4 months ago 2 Members · 4 Replies
  • Jason Hency
    March 24, 2017 at 3:37 pm
    This isn’t happening at export this when I’m working in a project. See the images below, there should be a master audio track in both the sequence panel and the audio mixer panel and there isn’t. I’m trying to figure out how to get it back.
  • Jason Hency
    March 24, 2017 at 8:33 pm
    Nope that’s not it either, I had checked that before posting the first time. If you look at the images the master audio track simply are not there. I’ve tried generating a new sequence the since normally when you first create one Master Audio is part of the tracks automatically generated but their are none for any flavor of sequence I create. Is this something specific to an iMac? My previous edit machine, which was an HP Z820, always generated a Master Audio track both in any sequence and in the audio mixer. But for some reason it’s not with this iMac. I was recently relocated from one office to another so I don’t access to the HP workstation anymore, btw.
  • Andy Edwards
    March 25, 2017 at 1:51 am
    Your picture is of the “Audio Clip Mixer” and not the “Audio Track Mixer.” Go to top menu / Window and down to Audio Track Mixer and select it. You should now see your A1,A2,A3 & a Master Track.
    Andy Edwards
  • Jason Hency
    March 27, 2017 at 12:39 pm
    Hah! Awesome, I knew it was something stupidly simple but could not figure out what I was missing. Thanks so much!
