Activity › Forums › Apple Final Cut Pro Legacy › Missing Edit Tab in FCP 7
  • Harry Bromley-davenport
    April 19, 2011 at 10:32 pm
    Please do post your findings here.
    Best
    Harry.
  • John Marsh
    April 19, 2011 at 11:16 pm
    Yes, please let us know how to fix this vexing problem. I’ve been tracking how to address it for some time now.
  • Dave Farrants
    June 20, 2011 at 9:03 am
    Just did a search and found this thread, I have the same problem – Edit disappearing from the menu bar. It happened on an old G5 with FCP6.0.6, I lived with it but it’s now happening on a new MacPro Quad with a clean install of SL & 6.0.6 and then a 7 upgrade. I’ve found it happens immediately after using the Text generator – obviously a bug or a common plugin problem.
  • Jeremy Garchow
    June 20, 2011 at 4:00 pm
    [Dave Farrants] “I’ve found it happens immediately after using the Text generator – “
    Which generator?
  • Dave Farrants
    June 20, 2011 at 4:10 pm
    The standard Apple Text generator, just tried it again and you can watch the EDIT menu item just disappear…..!
  • Dave Farrants
    June 20, 2011 at 4:29 pm
    Jeremy, now I’ve played with it, it’s any of the generators when you use the “A” button in the viewer window but not if you use the same generator from the generator panel in the effects tab and drag the generator to the timeline.
  • Jeremy Garchow
    June 20, 2011 at 4:36 pm
    Strange. It doesn’t happen here.
  • Dave Farrants
    June 20, 2011 at 4:41 pm
    No worries, now I’ve found the work around I can live with it, just not got round to trying to sort it till today (a quiet day!).
  • Tom Stovall
    August 9, 2011 at 7:46 pm
    This happened to me as well when I clicked on the A then select any of the MATTE, BORIS or other options, EDIT disappears and everything slides down to replace it.
  • Steve Forsyth
    September 9, 2011 at 2:57 pm
    FIXED!!
    We had the exact same issue – losing EDIT menu when clicking the “A” for effects. What we did was start pulling folders one by one out of the APPLICATION SUPPORT / PLUG-INS folder on the Hard Drive. Finally, when we pulled the MOTION TEMPLATES, the problem immediately stopped. I don’t know if one of those files was corrupted, or what, but it tells me it is a MOTION issue.
    Anyway – FIXED!
Page 4 of 5
