Activity › Forums › Apple Final Cut Pro Legacy › Missing Edit Tab in FCP 7
Posted by John Marsh on December 10, 2010 at 12:25 amMy edit tab in FCP 7 keeps disappearing. I can re-boot and it comes back for a bit, but trashing preferences with Preference Manager doesn’t fix it. Suggestions?
Mike Murphy replied 14 years, 1 month ago 12 Members · 44 Replies -
Jeremy Garchow
December 10, 2010 at 12:54 amI’m sorry, but my mind is blanking. What’s the edit tab?
John Marsh
December 10, 2010 at 1:05 amFinal Cut Pro, File, Edit, View…… etc.
At the top of the program in the top bar.
Says: “Edit” – it keeps disappearing
(contained it it’s drop down are ‘copy, cut etc.’
JMarsh -
Bret Williams
December 10, 2010 at 1:10 amThat’s not a tab. Never wouldve guessed that. You should probably trash your preferences, repair permissions, and run disk warrior. If you haven’t simply rebooted your computer that might be all it takes. But I just assume you’ve tried that.
John Marsh
December 10, 2010 at 1:13 amDid all except ‘disc warrior’ so I will take that tip and then check in.
Jeremy Garchow
December 10, 2010 at 1:45 amIt only does this in FCP?
Do you have Boris open or something?
John Marsh
December 10, 2010 at 2:00 amYeah, only in FCP. Ken Stone has never heard of this happening either. I suspect the program is corrupted.
Jeremy Garchow
December 10, 2010 at 2:10 am[John Marsh] “I suspect the program is corrupted.”
I’d go deeper than the program…but first:
Easiest thing to do woudl be uninstall and reinstall FCP. If it remains, then unfortuantely it’s time to rebuld the whole system.
Does it completey disappear and leave a space? Or do the rest of the menus ripple down?
Jeremy
Jeremy Garchow
December 10, 2010 at 2:17 amSo the Edit menu is essentially replaced by the View menu? That is a really weird one.
