Activity › Forums › Apple Final Cut Pro Legacy › Missing Edit Tab in FCP 7
  • Jeremy Garchow
    December 10, 2010 at 2:22 am
    [John Marsh] “How do you do that?”
    You tell me, it’s happening to you.
  • John Marsh
    December 10, 2010 at 2:25 am
    I meant, “how do you do the move to basics forum’ – – which I did.
  • Jon Chappell
    December 10, 2010 at 2:26 am
    Sometimes I get weird drawing glitches on menus, such as two applications’ menus being drawn over the top of each other.
    However, issues like these are purely cosmetic and it’s simply a matter of cmd-tabbing away and then back again or clicking on a menu item and moving the mouse horizontally.
    Do these suggestions fix the issue or is your Edit menu actually missing?
    My software:
    FCS Maintenance Pack – Tools to keep Final Cut Studio running smoothly and fix problems when they arise
    FCP Versioner – Backs up Final Cut Pro projects to XML and creates changelists for each revision
    More tools…
  • Jeremy Garchow
    December 10, 2010 at 2:28 am
    [John Marsh] “I meant, “how do you do the move to basics forum’ – – which I did.”
    That’s a permanant link on Creative Cow. I didn’t put that there. 😉 It’s on the bottom of every post in the FCP forum.
  • Jeremy Garchow
    December 10, 2010 at 2:29 am
    [Jon Chappell] “Do these suggestions fix the issue or is your Edit menu actually missing?”
    That’s exactly why I asked if the menu ripples or not. I thoght it might be some sort of display issue as well.
  • Harry Bromley-davenport
    December 10, 2010 at 2:39 am
    ME TOO!!!
    This is not constant condition with me and, because I know the keyboard shortcuts, I seldom notice that it is missing.
    I find that quitting and restarting Final Cut restores the EDIT tab. And when I have quite I usually trash prefs too.
    So I have no answer, but …
    Hey – it could be worse, right? But I can’t trace it to anything and you are the first person I have encountered you has this issue.
    Best wishes,
    Harry.
  • John Marsh
    December 10, 2010 at 2:40 am
    Am rebuilding permissions after using diskwarrior, then I will try your suggestions. the ripple is automatic, edit tab simply gone and only in this program.
    December 10, 2010 at 2:43 am
    I have tried EVERYTHING — and I can’t find a solution.
    I live with it and simply tell myself that FCS was not written to military spec.
    Harry
  • John Marsh
    December 10, 2010 at 2:47 am
    I have to do this repeatedly.
    December 10, 2010 at 2:49 am
    Let’s form a club.
    Harry.
Page 2 of 5
