Activity › Forums › VEGAS Pro › Merging projects, changes color in preview window
  • Merging projects, changes color in preview window
    Posted by Rick Longworth on November 18, 2014 at 3:44 am
    I’m merging several projects into a master level project. When I do this, the color images (not B&W) in the preview window are grainy and very over-saturated. Why is this happening. Is there a corrective measure?
    I am using Sony Vegas Pro 12;
    project properties is HDV 1080-24p (1440×1080, 23.976 fps)
    Thanks.
    Steve Rhoden replied 11 years, 10 months ago 6 Members · 24 Replies
  • 24 Replies
  • Graham Bernard
    November 18, 2014 at 7:21 am
    Rick, are you MERGING two already rendered-out files OR are you Nesting two VEG files?
    Grazie
  • Steve Rhoden
    November 18, 2014 at 9:26 am
    You simply may have a filter/effect on the timeline you are dropping
    them on.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • John Rofrano
    November 18, 2014 at 11:20 am
    It sounds like you may be applying FX twice. If in one project you added FX to the track, but in another you added them to the event, and now you move the event with FX onto a track with FX you get double FX. Check that you didn’t do this.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Graham Bernard
    November 18, 2014 at 2:07 pm
    Hey, guys, how about the MP4 stretch?
    G
  • Rick Longworth
    November 18, 2014 at 8:27 pm
    John, I think your suggestion is correct. It makes sense. I tried to discover which elements are causing the problem so I could deal with it. However, the larger of my two projects is quite complex and includes many pre-rendered segments and some other fancy footwork. I was unable to determine where there is a duplication of FX. I tried separating the complex project into smaller and smaller segments to isolate the offending parts, but even the smallest components lead to the same strange appearance of the preview window. I may just have to live with it. The rendered product looks just fine, its just that the preview window is not good for an early review of fine details.
    Thanks all for your suggestions. Any other thoughts?
  • John Rofrano
    November 18, 2014 at 9:18 pm
    Why don’t you use Nested Projects? Start a new project and drag the other project files into it. They will behave as single pieces of media.
    ~jr
  • Rick Longworth
    November 18, 2014 at 9:48 pm
    That’s just what I am trying to do. Nesting (didn’t know the term). Sorry if I was not clear in describing my situation. I drag in the first project and the preview window looks fine. I drag in a second project, and I get wonky color in the preview window.
    One thing I tried was to move the second project down onto a lower track so the two projects would not be effecting each other. No luck.
    Can you suggest a way to narrow down the problem? When I delete parts of the second project hoping to get rid of the offending segments, I do not find it. The problem persists with even small bits of the project included.
  • John Rofrano
    November 19, 2014 at 4:50 am
    [Rick Longworth] “I drag in the first project and the preview window looks fine. I drag in a second project, and I get wonky color in the preview window.”
    What if you just drop the 2nd project into a new project? Does it look bad then? It may have something to do with nesting the second project.
    ~jr
  • Rick Longworth
    November 19, 2014 at 5:09 am
    Yes, I tried dropping the second (offending) project in an empty project. It still looks very sick. I tested 3 other projects and they all look fine. It looks like somethings wrong with project 2, but I don’t know what. Perhaps if I try to recreate parts of project 2 from scratch until it breaks?
  • John Rofrano
    November 20, 2014 at 2:43 am
    Yea, you need to figure out what’s wrong with project 2 and why it can’t be nested without looking bad. Of course, you could always just render it out and use the rendered video which should look fine.
    ~jr
Page 1 of 3
