Activity Forums Adobe Premiere Pro Media Encoder changing 16:9 Aspect Ratio to 4:3 (mac)
  • Media Encoder changing 16:9 Aspect Ratio to 4:3 (mac)
    Posted by Lachlan Tetlow-stuart on April 26, 2009 at 5:01 am
    My problem is attempting to export a number of projects from Premiere Pro (CS4 – 4.0.1) through Media Encoder in the 16:9 aspect ratio. I get this problem across basically every codec i try.
    When viewing the “output” view in Media Encoder – the aspect ratio is right. It’s also correct in the preview window as the render is in progress. When I use the info screen on the output file to gather info on the pixel aspect ratio – this is also correct. Yet when i play the file in QT – the video is squashed into 4:3.
    I’m able to play other 16:9 video’s in QT – it’s only when it is exported from Premiere Pro. If I reimport it into Premiere Pro or burn it to DVD – the 16:9 ratio fixes itself…
    I’ve recently upgraded computers (macs) and this problem occurs on both of them.
    Thanks in advance
    Lachlan
    Lachlan Tetlow-stuart replied 17 years, 3 months ago 2 Members · 4 Replies
  • Eddie Lotter
    April 26, 2009 at 3:26 pm
    I seem to recall (but don’t know authoratively) that QT player does not handle non-square pixels. If you want 16:9 you need to use square pixels and an appropriate pixel resolution.
    Cheers
    Eddie
  • Lachlan Tetlow-stuart
    April 27, 2009 at 7:36 am
    WOW!!!!
    Thankyou. That little revelation has changed my digital world!
    Just to confirm – HDV camera’s produce a 1440 x 1080 image in 1.333 pixel ratio? I think this was part of my confusion around it all…
    Thank you again!
  • Eddie Lotter
    April 27, 2009 at 1:55 pm
    [Lachlan Tetlow-Stuart] “HDV camera’s produce a 1440 x 1080 image in 1.333 pixel ratio?”
    I believe so (I don’t use HDV), so you need to export to a 1920×1080 frame size with a 1.0 pixel aspect ratio for QT playback.
    Cheers
    Eddie
    April 29, 2009 at 10:52 pm
    Yes. Brilliant!
    Lachlan
