Activity Forums Adobe Premiere Pro Maximum Bit Depth /Maximum Render Quality CS4 Questions
  • Maximum Bit Depth /Maximum Render Quality CS4 Questions
    Posted by Jeff Hall on March 6, 2009 at 5:38 pm
    Maximum Bit Depth
    If my project contains high-bit-depth assets generated by high-definition camcorders, I was told to select Maximum Bit Depth because Adobe Premiere Pro uses all the color information in these assets when processing effects or generating preview files. I’m capturing HDV using the Matrox RTX-2 Hardware in Matrox AVI format.
    When I finally export my project using Adobe Media Encoder CS4, will selecting Maximum Bit Depth provide better color resolution once I post to Blu-Ray format?
    I was told that by using Maximum Render Quality, I Maintain sharp detail when scaling from large formats to smaller formats, or from high-definition to standard-definition formats as well as maximizes the quality of motion in rendered clips and sequences. It also renders moving assets more sharply. It’s my understanding that at maximum quality, rendering takes more time, and uses more RAM than at the default normal quality. I’m running Vista 64 Bit with 8 GIGs of RAM so I’m hoping to take advantage of this feature.
    Will this also help to improve the resolution when I finally export my project using Adobe Media Encoder CS4 and post to Blu-Ray format?
    Eddie Lotter replied 17 years, 5 months ago 3 Members · 2 Replies
  • Rey Rodman
    April 21, 2009 at 1:00 pm
    hey hows it going iam having a problem when i export my files they look good on my comp but when i burn my project to dvd it has problems wit resolution i see the pixels breaking up what iam i doing wrong what is the best way to export a project an what are the best settings for a full quality export and burn on a dvd i dont get the resolution problem when i play bak from comp but when i burn a dvd an play it on dvd it is bad plz help me out
  • Eddie Lotter
    April 21, 2009 at 4:02 pm
