Activity Forums Adobe After Effects Match Grain Goes Wonky
  • Match Grain Goes Wonky
    Posted by Zak Ray on August 28, 2010 at 3:34 pm
    Saw a few other threads with this problem, but no solutions that worked. When applying match grain to a clip, it seems to work perfectly most of the time, but every so often, for a few frames, it will just go crazy and crank the grain way up.
    Normal:
    Wonky:
    Zak Ray replied 15 years, 11 months ago 35,296 Members · 2 Replies
  • Zak Ray
    August 28, 2010 at 5:05 pm
    Also, it won’t accept certain layers as sources for the grain; if I try it on another clip and tell it to use that layer it works, but not on the clip I need it to. Any thoughts?
  • Zak Ray
    August 30, 2010 at 11:32 am
    Anyone? If not a fix, I’ll take any ideas on a workaround.
