Mask appears in different location in the preview window
Baskeh Dewitt replied 1 year, 6 months ago 3 Members · 16 Replies
Jurgen Murataj
February 11, 2025 at 12:40 amCan you try a test render just to see if the mask appears correctly on the final video? Sometimes the preview will glitch like that.
Jurgen Murataj
February 11, 2025 at 2:27 amThere is definitely something in the settings that’s messing with this, but I cannot identify that problem based on the screenshots provided. What I’d do to just finish this project, is trying to rotate the mask manually. To do that, you just double click on the mask outline so it selects all of it, then click, hold and drag anywhere within the circle as displayed in the picture to rotate it. Make sure to line it up with the preview and you’ll have it in the position you want.
Lucien Vaillancourt
February 11, 2025 at 2:11 pm -
Baskeh Dewitt
February 12, 2025 at 1:49 amHi again!
Just though of this, so why not give it a shot: When comparing your mask to the preview, it looks like the mask is sort of stretched. I’m guessing due to a mismatch in aspect ratio. Try checking the Pixel Aspect Ratio in both the Project Properties and Event Pan/Crop settings to ensure they’re set to 1.000 (Square Pixels).
To fix this:
- Project Properties → Go to File > Properties and set Pixel Aspect Ratio to 1.000 (Square Pixels).
- Event Pan/Crop → Open the Pan/Crop window, disable ‘Stretch to Fill Frame’, and try ‘Match Output Aspect’ by right-clicking inside the workspace.
Hope this helps, looking forward to hearing from you again!
Baskeh Dewitt
February 16, 2025 at 10:47 pmHi again Lucien!
Just checking in to see if you were able to resolve this issue?
