Activity › Forums › Letters to the COW Team › Markup errors in forum posts
Tim Wilson
September 24, 2020 at 7:43 amHi Graham,
Yes indeed, thanks for the report!
It does appear to only happen after the quote styling, so I am going to have to test this some more.
Once again, though, I fixed it simply by going into admin edit mode, where the post displayed properly, hit save (again, after doing nothing), and it now looks fine.
My larger concern is that you said that you couldn’t edit your post after you made it. Is that still the case? Our system is supposed to allow editing for 30 minutes after you make a post. Can you please doublecheck that? You can do it here, or in the Test Posting forum. I’ll be headed there myself in just a bit to see if I can pin down the circumstances of the markup error.
Thanks again!
Graham Bernard
September 24, 2020 at 8:19 amWe have a Test Posting Forum? I didn’t know. Can you give me a Link?
The edit bit was I was attempting to edit-out the HTML. I couldn’t do it and just gave up.
Brie Clayton
September 24, 2020 at 1:36 pm
