Activity Forums Adobe After Effects Making Rainbow Trails off of a PNG
  • Making Rainbow Trails off of a PNG
    Posted by Matthew Chapman on January 4, 2013 at 1:18 am
    Hi all-
    Trying to make rainbow trails off of a simple PNG, in a 5 second comp.
    I tried following these instructions from David Rickles and get nothing. no change to my comp whatsoever. I bought trapcode particular just for this.
    https://forums.creativecow.net/thread/50/856087
    What I have is a PNG of a mushroom
    And what I want is the trails (done in photoshop)
    I have tried both trapcode Particular and echo, and no real luck.
    I would like to keep the color scheme of the trails too (more earthy tones than neon)
    Any suggestions?
    Thanks all!
    matt
    Tudor “ted” jelescu replied 13 years, 8 months ago 5 Members · 11 Replies
  • 11 Replies
  • Tom Daigon
    January 4, 2013 at 1:47 am
    You mean something like this? (AE and Particular)
    or this
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • Matthew Chapman
    January 4, 2013 at 2:02 am
    I guess it would be more like the color of the first, but the detail of the second.
    The mushroom also needs to spin as it goes. So for instance I set the PNG to 0 rotation, then moved the cursor to the end and set it to -1. Then I pre-composed the layer, but still didn’t see any trails when using particular, and selecting the layer as the particle.
    Thanks Tom!
  • Tom Daigon
    January 4, 2013 at 2:25 am
    Glad to help Matthew. Heres the CS6 Project if you want to analyze it.
    5153_mushroomfolder.zip
    Tom Daigon
    HP Z820 Dual 2687
    64GB ram
  • Matthew Chapman
    January 4, 2013 at 3:06 am
    Thanks Tom-
    I am looking forward to it (have a few client things to handle for a min)
    matt
  • Darby Edelen
    January 4, 2013 at 4:45 am
    Alternatively, you can achieve some rainbow trail effects using:
    Echo + Coloroma
    or
    CC Time Blend FX + Hue/Saturation
    These methods both have what might be significant downsides* but they may also be exactly what you’re looking for 🙂 So here’s my contribution in project file form for your perusal:
    5154_shroomfolder.zip
    I used solid colors in the Time Blend FX example but you could also tritone the image instead of using fill and then rotate the hue in the same fashion.
    *The blending when using Echo isn’t ideal. Time Blend FX uses previously cached frames and so sometimes misbehaves. It also is not compatible with render multiple frames simultaneously.
    Darby Edelen
  • Matthew Chapman
    January 4, 2013 at 5:29 am
    Thanks Darby! I’ll check them out.
  • Matthew Chapman
    January 4, 2013 at 5:37 am
    I really like the echo + colorama Darby, it’s perfect.
    Now I have done many things in AE, and maybe I am just not getting a basic concept, but How did you get the FX to apply to the layer without being a part of the comp itself.
    Admittedly, AE is a hobby for me, not a full time job, but like I said I have made some pretty advanced comps in my time. Maybe I am missing something pretty basic?!
    Chap
  • Matthew Chapman
    January 4, 2013 at 5:41 am
    Maybe I should be in beginner guys, BUT i tried applying echo to a pre-comped spinning Mushroom, and no luck. What the devil am I doing wrong?!
    File here:
    5155_shroomecho.aep.zip
    I did watch the tutorial including nesting and precomposing. I did pre-compose the layer but the echo still shows no effect.
    Argh
  • Vishesh Arora
    January 4, 2013 at 5:58 am
    matthew
    I made the Rainbow trails using Particular. Hope this may help.
    CS6 File: 5156_mushroomrainbowparticular.zip
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Darby Edelen
    January 4, 2013 at 6:32 am
    [matthew chapman] ” Maybe I should be in beginner guys, BUT i tried applying echo to a pre-comped spinning Mushroom, and no luck. What the devil am I doing wrong?!”
    You need to apply your transformation keyframes inside the pre-comp.
    Darby Edelen
