Activity › Forums › Creative Community Conversations › Magnetic timeline too Magnetic – Can’t turn off?
Posted by Russell Lasson on June 22, 2011 at 4:28 amSo sometimes I like to throw a clip at the end of a sequence or move clips later in a timeline and have a gap. In FCPX, do I have to add a gap to make that work? Can I just turn off the magnetic timeline and slide stuff around so that I have gaps or do I always need to insert a gap to make it do what I want?
Russ
Russell Lasson
Colorist/Digital Cinema Specialist
Color Mill
Salt Lake City, UT
http://www.colormill.netMitchel Hansen replied 13 years, 5 months ago 10 Members · 14 Replies -
Tom Daigon
June 22, 2011 at 4:33 amI read somewhere here that if you use the POSITION control it temporarily turns off the magnets.
Tom Daigon
Avid DS / FCP / After Effects Editor
http://www.hdshotsandcuts.com -
George Manzanilla
June 22, 2011 at 4:36 amit’s called f’n BS… you can’t turn it off.
Apparently in all the user requests to Apple on FCP, messing with something that wasn’t broken was at the top.
george manzanilla
rundfunk media
http://www.rundfunk.com -
Chris Kenny
June 22, 2011 at 4:51 am[Russell Lasson] “So sometimes I like to throw a clip at the end of a sequence or move clips later in a timeline and have a gap. In FCPX, do I have to add a gap to make that work? Can I just turn off the magnetic timeline and slide stuff around so that I have gaps or do I always need to insert a gap to make it do what I want?”
Flip from ‘Select’ mode to ‘Position’ mode, and clips will go exactly where you drag them, overwriting other clips or leaving gaps as necessary. To delete a clip and leave a gap, use ‘Replace With Gap’ instead of just deleting normally. (‘Replace With Gap’ is assigned to the forward delete key.)
A couple of more useful semi-related features: if you drop a clip on another clip in the timeline, a contextual menu will give you replacement options. Also, you can now insert specific (named) placeholder clips (with Edit -> Insert Placeholder), so things you intend to fill in later don’t just have to be gaps named with markers anymore.
Digital Workflow/Colorist, Nice Dissolve.You should follow me on Twitter here. Or read our blog.
Ts O’grady
June 22, 2011 at 5:01 amThanks Chris. You’ve been working hard today getting the right information to the people who are interested in resolving issues and learning more about how FCP X actually works.
Jonathan Dortch
June 22, 2011 at 5:07 amGreat tip will try this tomorrow first thing. timeline issues are my biggest concern. thanks for all the info today!
JONATHAN DORTCH
BLACK WOLF CREATIVE -
Russell Lasson
June 22, 2011 at 5:10 amRight on.
I think I’d like to be able to switch between Select and Position mode while I’m dragging a clip, just like how you can turn snapping off and on while dragging a clip.
Russ
Russell Lasson
Color Mill
Salt Lake City, UT
http://www.colormill.net -
Nate Weaver
June 22, 2011 at 5:46 am[Chris Kenny] “Flip from ‘Select’ mode to ‘Position’ mode, and clips will go exactly where you drag them”
Oh my god. I had been figuring out a LOT of stuff on my own, and getting to the point where I am definitely cutting faster than I was before, but between this and the other things I learned today, I can take over the world.
Folks, you need to stop complaining and look at what can be done. So far, I have found either a minor workaround to almost every problem I’m finding, or just a flat out better/faster way to get things done.
Thanks so much, Chris.
Nate Weaver
Director/D.P., Los Angeles
https://www.nateweaver.net -
Chris Conlee
June 22, 2011 at 5:56 amHey Nate,
What’s your simple work around for printing to tape? Or getting an EDL to the colorist? Or multicam editing? Or getting client monitoring working?
Looking forward to those tips.
Chris
Nate Weaver
June 22, 2011 at 6:10 am[Chris Conlee] “Looking forward to those tips.”
I said almost every issue.
Love your snark.
Nate Weaver
