Activity Forums Apple Final Cut Pro Legacy Mac Pro Refusing to Render
  • Mac Pro Refusing to Render
    Posted by Justin Coleman on January 14, 2008 at 1:24 pm
    Hey Guys,
    I’ve just had this error and wondered if anyone could shed some light on it for me.
    “The effect “Light Rays” failed to render: Your hardware
    cannot render at the requested size or depth.”
    Im using an Apple ProRes timeline with HDV footage that I copy and pasted from an HDV timeline in order to allow me to send it to Color. Its 1440×1080 50i.
    The machine Im using is a Quad Mac Pro with 3gbs of RAM and a NVIDIA GeForce 7300 graphics card. No video capture card.
    Cheers
    Justin
    Andrew Hamilton replied 18 years, 6 months ago 4 Members · 5 Replies
  • Gabriele De simone
    January 14, 2008 at 2:09 pm
    I’m guessing that you’re getting an error because you’re trying to render the sequence at one of the high-precision settings, but your graphics card does not have sufficient video memory to do that. If my guess is correct, try the following:
    – Open your Sequence Settings window
    – Switch to the Video Processing tab
    – Select the “Render in 8-bit YUV” option
    – Re-render the sequence
    HTH,
    Gabe
    Noise Industries, LLC
    https://www.noiseindustries.com
  • Justin Coleman
    January 14, 2008 at 2:46 pm
    Yer thats done it, you are a genius!
    Thanks.
    Whilst doing that, I noticed that there was another Apple ProRes setting labelled HQ, how does that differ from the non HQ one?
    Thanks again.
    Justin
    January 14, 2008 at 3:03 pm
    The ProRes codec uses VBR (variable bit rate) encoding, and as far as I know the HQ vs standard ProRes sequence settings simply tell FCP how much “bandwidth” your output should use.
    You can get this info by choosing the “HD and Broadcast Formats” command under the FCP Help menu. If you scroll down to the section titled “About the Apple ProRes 422 Codec”, you’ll get the exact bit rates used by the HQ and standard settings.
    Lower bit-rate obviously means lower quality, but also lower requirements on your I/O (especially when editing/transferring over a network). I don’t think anyone has tested how much slower the HQ settings are though, it would be interesting to have that data…
    Gabe
  • Paul Escandon
    January 14, 2008 at 5:00 pm
    ProRes 422 (non HQ) has a target bit rate of 145 Mbps, while ProRes 422 HQ has a target bit rate of 220Mbps. Depending on the type of material you’re working with, though, a lot of people state they can’t see a difference between the two. It’s worth checking out for yourself so you can see if you can save a little space.
    Paul Escandon – Lead Editor @ Outdoor Channel
    Producer | Director – Oremus Productions
    http://www.oremusproductions.com
    Apple Certified Trainer – Final Cut Pro
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • Andrew Hamilton
    March 12, 2008 at 9:28 pm
    This rendered for me, however, I got a really really bad looking jittery effect with the plugins that were refusing to render prior to the change to 8 bit yuv. Anyone have any ideas on how to remedy that or am I just screwed from using those on my system?
    Andrew Hamilton
    DVD Developer
    Ultimate Fighting Championship
    http://www.ufc.com
    Las Vegas Video Production
    Hamilton International Productions
    https://www.hiproductions.com
