Activity Forums Apple Final Cut Pro Legacy Mac Pro CPU Temperatures?
  • Mac Pro CPU Temperatures?
    Posted by Chris Wiggles on March 19, 2011 at 7:53 pm
    I did some googling, couldn’t really find good answers.
    I have an 8-core Nehalem Mac Pro (2 x 2.26ghz).
    Been running compressor all night, 8 more hours to go. How hot is too hot for these CPUs?
    Temperature monitor reports:
    CPU A: 80C
    CPU B: 61C
    And the hottest cores range around 87-89 degrees C.
    istat pro says my boost A&B fans are running around 3200rpm.
    I’m in a 68degree F room.
    Is this all normal or should I be concerned? Just curious what your experiences are when processing.
    Regards,
    Chris
    Chris Wiggles replied 15 years, 6 months ago 5 Members · 6 Replies
  • David Roth weiss
    March 19, 2011 at 8:17 pm
    There’s a heat sensor on the main-board that will do the monitoring for you automatically. When your Mac suddenly shuts down and smells like burned toast you need to start worrying, but until then just keep being creative.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Scott Sheriff
    March 19, 2011 at 10:05 pm
    I ran a temp widget on my machine for a while just for grins, and your readings seem typical.
    I wouldn’t worry.
    Scott Sheriff
    Director
    https://www.sstdigitalmedia.com
    I have a system, it has stuff in it, and stuff hooked to it. I have a camera, it can record stuff. I read the manuals, and know how to use this stuff and lots of other stuff too.
    You should be suitably impressed…
  • Zane Barker
    March 19, 2011 at 10:09 pm
    The temp sensors should turn the computer off before it gets to hot.
    **Hindsight is always 1080p**
  • Rafael Amador
    March 19, 2011 at 10:16 pm
    I used to place a domestic fan in front of my G5 and go to sleep.
    As soon as I put it, at the lower speed, the G5 fans slowed down.
    rafael
    http://www.nagavideo.com
  • David Roth weiss
    March 19, 2011 at 10:54 pm
    Keep in mind that Rafael lives in the tropical environment of Laos. So, his computer is hot before he even turns it on.
    David Roth Weiss
    Los Angeles
  • Chris Wiggles
    March 20, 2011 at 7:08 pm
    Great, thanks for the help guys!
    Good to know these are normal readings when going at full tilt.
    Regards,
    Chris
