Activity Forums Apple Final Cut Pro Legacy Mac maintenance
  • Mac maintenance
    Posted by Kim Rowley on November 28, 2006 at 10:38 am
    I have been editing full time on my current mac (bought in August 2005 see specs in signature). I have a brief window of time this week in between jobs and wondered what are good common practices to acquire to keep my mac happy? I usually trash my media which is captured project by project and archive the data related to the final FCP project. I just downloaded OnyX to run some of those cleanup features, but are there any other wise things to do periodically, for the Mac and also for the XRAID?
    Thanks for your experience.
    Dual 2.7 GHz G5, 4GB RAM, ATI Radeon 9650, Xserve RAID, AJA IO, 2 20″ Cinema Display, FCP 5.03, OS X10.4.3
    James Bayliss-smith replied 14 years, 7 months ago 8 Members · 12 Replies
  • 12 Replies
  • Lee Berger
    November 28, 2006 at 1:14 pm
    I run the suite of tests in Tech Tool when I’m not busy. Tests hardware and software.
    https://www.micromat.com/index.php?option=com_content&task=view&id=174&Itemid=85
    Lee Berger
    http://www.leebergermedia.com
  • Walter Biscardi
    November 28, 2006 at 1:48 pm
    [Kim Rowley] “I usually trash my media which is captured project by project and archive the data related to the final FCP project.”
    Not only trash the media, but erase your media drives often, at least every three months if possible. Just trashing the media still leaves you with a fragmented drive, you want a good clean erase as often as possible.
    Other than that I’ll run Repair Disk Permission and Disk Warrior from time to time to clean up my System Drive.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Kim Rowley
    November 28, 2006 at 2:13 pm
    Thanks Lee, thanks Walter. I’ll look into both of those suggestions.
  • Matt Callac
    November 28, 2006 at 3:31 pm
    I run MacJanitor every monday first thing in the morning, As I tend to shut my machine down over the weekend.
    -matt
  • Matt Larson
    November 28, 2006 at 3:43 pm
    There is a program called “Maintenance” that I found on the Apple Downloads page that seems to work pretty well.
    For the XRAID, I always “Condition Drive Array” when I have time (it takes about 24 hours and can but can be performed in the Background). You can select it from the RAID Admin Utility under “Utilities”. I always see a noticible performance increase afterwards.
  • Lee Berger
    November 28, 2006 at 10:21 pm
    Matt,
    I’ve run “condition drive array” as well and obtained improved performance. Do you know what it actually does? Is it defragmenting?
    Lee
    Lee Berger
  • Lee Berger
    November 28, 2006 at 10:28 pm
    Walter,
    I agree with trashing and erasing periodically, but I have media from long term projects on my XServe RAID that I can’t trash. Would you recommend defragmentation as an option to full erase?
    Lee
    Lee Berger
  • Miodrag Ristic
    November 29, 2006 at 1:10 pm
    Kim,
    It’s 21st century, we don’t defrag any more.
    No wonder, there are so many people reporting drive failures:
    “Defragmentation on HFS+ volumes should not be necessary at all, or worthwhile, in most cases, because the system seems to do a very good job of avoiding/countering fragmentation.
    It is risky to defragment anyway: What if there’s a power glitch? What if the system crashes? What if the defragmenting tool has a bug? What if you inadvertently reboot? In some cases, you could make the situation worse by defragmenting.”
    I was told the same by Apple technician @ local Apple Centre two years ago.
    Complete article:
    https://www.kernelthread.com/mac/apme/fragmentation/
    All that I do is repairing permitions, before & after every install.Occasional restart as well.
    With hard drives common sense; do not move them
    whilst working, unmount them before disconnecting and keep them cool.
    Cheers
    Mick
  • Walter Biscardi
    November 29, 2006 at 1:26 pm
    [Miodrag Ristic] “”Defragmentation on HFS+ volumes should not be necessary at all, or worthwhile, in most cases, because the system seems to do a very good job of avoiding/countering fragmentation.”
    Defragmentation while media is on the drives is not a good idea I agree, but you should erase the drives as often as possible to maintain the best possible performance from your media arrays. I believe many of the hard drive problems we see on these forums are because people simply don’t maintain their arrays by cleaning them from time to time.
  • Kim Rowley
    November 29, 2006 at 3:10 pm
    Thanks to Walter, Lee and all. I was unaware that it was good practice to unmount the drives before shutting down. I’ll start doing that tonight.
    Cheers!
