Activity › Forums › Storage & Archiving › LTO cartridge taking long time to erase new/old media
Neil Sadwelkar replied 4 years, 12 months ago 5 Members · 23 Replies
Neil Sadwelkar
January 21, 2021 at 5:31 amHari,
Unless its a typo, I noticed that you’ve written you are using an Atto R680 card and not an Atto H680. The R680 is a RAID card as far as I remember, and (hope Martin doesn’t mind) I’m reproducing this from Yoyotta’s support page…
“ATTO ThunderLink SH1068, SH2068 TB-SAS, ThunderStream SC4808 adaptors, R680 or R644 PCIe RAID SAS cards do not support TLR which is a required protocol. So they are not compatible with LTFS running on any operating system.”
So, maybe that’s the problem in your installation. The SAS card you’re using R680 doesn’t support TLR, hence LTFS.
Have you tried, or can you try with this drive and connecting via a H680 or H1280, and see if that makes a difference.
Neil Sadwelkar
Hari Krishna pune
January 21, 2021 at 5:43 amDear Neil,
As you said I have also referred the support page from yoyotta’s website. I do have that in mind and some times when I get other kinds of TLR related errors I will remember what the page said. I don’t think this is kind of problem could be happened through R680. Even though to confirm that I have used my old sas card IBM LSI 2008 which came along with my old Ibm drive in a windows machine the result doesn’t changed a bit.
other kind of problems like while deleting an written file from the media it will object with a copyright protection and some times while we are doing backup also I have faced copyright error can cause through ATTO R680 I hope.
And also I have been doing regular backups using the same card since 2016.
Hari Krishna pune
January 21, 2021 at 5:52 amDear Tim,
I have tried wiping the media using terminal since I took your advice earlier hasn’t changed the results in any way.
As far as I concern about temperature the temperature of the room is at 20c, humid levels are low and it’s a clean room. we will getting lot of dust everyday as it is faced a main street and the vehicle traffic is moderate so. Our staff will clean the room everyday first thing in the morning and then we turn on the systems.
Hari Krishna pune
January 21, 2021 at 5:55 amThe other thing I am noticing from past two days is that when I am doing wipe, format or mount the whole table is vibrating because of the drive, it was not there earlier.
Hari Krishna pune
January 21, 2021 at 5:57 am -
Tim Gerhard
January 22, 2021 at 3:06 pmYou potentially have a bad drive or bad tape cartridge.
Since you said HP LTO6, I have to ask. What brand of cartridges are you using? You need to be using metal particle (MP) tapes in an HP LTO6. Sony and other off-brands made the MP LTO6 tapes before, but they’ve stopped making them for quite a while. If you have IBM or Fuji those are Barrium Ferrite (BaFE) and will cause harm to your HP LTO6 drive.
Try running HPE Library & Tape Tools (LTT) to run a diagnostic on the drive as well.
Hari Krishna pune
January 22, 2021 at 3:22 pmDear Tim,
I have been using only IBM media ever since I started archiving in weather it is any brand drive. As you advised I will run a diagnostic test using hp l&tt and will see what are the results are going to be.
Hari Krishna pune
January 23, 2021 at 10:20 amDear Tim,
Please check the below attached logs and the screenshots of the hpp_ltt test.
Device analysis test turned good.
connectivity test results are also fine.
I am getting an write error at read/ write test and asking me to clean the drive with a unexpired cleaning cartridge. I did and ran the test again. still the same issue.
I ran data assessment test where I got an error saying partitioned tape is not compatible for the test, even though I actually used an new cartridge I unpartitioned the cartridge and ran the test again, and the result is the tape has not enough data to finish the test. don’t get it.
Hari Krishna pune
January 23, 2021 at 1:09 pm -
Tim Gerhard
January 25, 2021 at 11:04 pmIf you’re using an IBM tape in an HP drive it can be throwing the write errors on LTO6. If you keep getting cleaning warnings, then the head can be bad on the drive.
Using the wrong media type ruins the head over time.
