Activity Forums Sony Cameras Low temps?
  • Low temps?
    Posted by Kent Beeson on December 7, 2009 at 9:54 pm
    Hi guys
    Real world camera and tripod experience re: low temps outside – is it safe to shoot with the EX1R around 30-32ºF for about an hour? How about Satchler FSB-6T fluid head tripod? Any problems with that freezing up after a few minutes?
    K
    web.me.com/kbcv
    Scott Morrison replied 16 years, 9 months ago 7 Members · 12 Replies
  • 12 Replies
  • Noah Kadner
    December 7, 2009 at 11:06 pm
    I don’t see why not- that’s not that cold…
    Noah
    Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera! Unlock the secrets of 24p, HD and Final Cut Studio.
    Call Box Training now featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II, Canon 7D, and Panasonic DVX100.
  • Kent Beeson
    December 7, 2009 at 11:35 pm
    Just wondered since the manual says 32º-104º – never shot in that low temp and wondered before I go out and do so if 30º ish was pushing it for EX1R.
    K
    web.me.com/kbcv
  • Craig Seeman
    December 7, 2009 at 11:37 pm
    I’ve shot with the EX1 and FSB6 in NYC during the winter where the tempartures can get lower at times without issue. I’ve done this after heavy snow and didn’t have condensation issues either. If you do get into even a light snow flurry situation protect the LCD first and foremost.
  • Kent Beeson
    December 7, 2009 at 11:42 pm
    Thanks – sounds like a little common sense and it’ll be fine.
    K
    web.me.com/kbcv
  • George Griswold
    December 8, 2009 at 12:58 am
    Keep that battery warm or your run time will tank. Don’t know if Li-ION batteries have freezing issues at colder conditions than you expect.
  • Kent Beeson
    December 8, 2009 at 1:32 am
    I’ve got a KATA rain bag, very nice, I suppose I could use that in snow, but anyone know about Sacthler fluid heads, if they freeze up below 32º or what precautions one should take for slightly below freezing shooting.
    K
    web.me.com/kbcv
  • George Griswold
    December 8, 2009 at 1:55 am
    Sachtler head will be fine… fluid may become thicker as temp drops…just like motor oil.
    Be careful with the camera when you go back inside because that is when you may have condensation. Any barrier to air contact until the camera warms up (even partially) is a good idea… depends on what humidity levels you encounter indoors.
  • Kent Beeson
    December 8, 2009 at 4:54 am
    Thanks for all the helpful replies, thoughts.
    K
    web.me.com/kbcv
  • Nigel Walker
    December 8, 2009 at 1:55 pm
    I had some problems on my EX1 with focusing after I left it in a car overnight in a snow storm. Not sure what the temp got down to but wasn’t too cold. problem went away after I took it inside and warmed it up for an hour or so. Not in aircon
    Nigel Walker
    Wild Films
    Australia
  • Clint Fleckenstein
    December 9, 2009 at 5:13 pm
    I was out last night with an EX1 and FSB-6 for just under an hour in -5 or so (windchill between -15 and -20). It worked fine. I was doing mostly stationary shots, but the tripod’s fluid head was REALLY stiff when I moved it. Of course I forgot to take it off its strongest drag setting before I went out. Camera ran fine, I didn’t even lose one dot of battery indicator, and I managed not to snap the tripod’s carbon legs in the cold as I moved it around. My headphone cord got so stiff I just propped it up against the camera.
    Gotta love North Dakota.
    Cf
