Activity Forums VEGAS Pro loop audio in DVDA menu
  • loop audio in DVDA menu
    Posted by Steven J casey on June 1, 2007 at 4:43 am
    I’m sure there’s an easy answer to this but I can’t seem to find it. I have an audio file about 30 seconds long that I want to play under a still shot on my menu. How do I loop it indefinitely until a selection is made? So far when I set loop points it takes away the buttons until the loop point is reached. I want the buttons to stay and just repeat the audio underneath.
    TIA
    steven
    Don Bloom replied 19 years, 2 months ago 2 Members · 1 Reply
  • Don Bloom
    June 1, 2007 at 10:20 am
    Go into the Menu Page Properties, End Actions, Command. there you have a default of HOLD but it can be changed to LOOP or Activate Button. Loop is want you want.
    Be aware though that if the music needs to be cut right so there’s not an obvious “hey heres the loop point” unless of course thats what you want.
    Don
